Ambient air temperature sensor
Postby gmg31 » Tue 20.08.2019, 21:13
Does anyone know what would happen if this went wrong?
Where is it?
What does it look like ?
Are they available ?
I’m struggling to figure out what is wrong with my car and Colin from Revline suggested I ask about this.
gmg31
Re: Ambient air temperature sensor
Postby Rambo » Tue 20.08.2019, 21:53
Do you mean the coolant temperature sensor (CTS) ?
Or the manifold air temp sensor (MAT) ?
viewtopic.php?f=34&t=14412&p=189762&hilit=Mass+air+temp+sensor#p189762
Postby gmg31 » Wed 21.08.2019, 07:39
Yes the MAT, I was given the wrong name. I’ve changed the CTS and that didn’t fix my problem.
gmg31
Postby Rambo » Wed 21.08.2019, 09:00
I think there us some info on this in Wikilec
Postby muley » Wed 21.08.2019, 09:57
gmg31 wrote:Does anyone know what would happen if this went wrong?
Where is it?
Can you tell us what the problem is? If it's overfuelling - failure of the Coolant Temperature Sensor is often to blame
Postby GeoffSmith » Wed 21.08.2019, 10:04
CTS already changed Jim.
viewtopic.php?f=33&t=27524
Postby muley » Wed 21.08.2019, 13:50
GeoffSmith wrote:CTS already changed Jim.
Thanks Geoff. I thought it was a fresh/new problem.
If it were me, I'd be running Elanscan...
Postby gmg31 » Wed 21.08.2019, 15:04
gmg31
Postby gmg31 » Wed 21.08.2019, 15:11
The problem with my problem is that it is entirely repeatable. I could take my car out for hours and she runs perfectly. But the moment I stop and rest for 10 mins she runs like a bag of spanners and only goes back to normal if I switch her off and allow her to cool down completly. I have changed the CTS and Ive tested the leads and coil packs. I can't imagine how any of the consumable parts could be so consistently inconsistent. They work perfectly and then they don't and then they work perfectly again and then they don't. Colin from Revline felt it was most likely has to be a sensor somewhere that is tricking the car, perhaps into thinking its a freezing cold day and she's overfulelling which would account for the backfiring.
gmg31
Postby Simon_P » Wed 21.08.2019, 15:52
Your symptoms are consistent with hot coil failure or perhaps leaking injectors. Neither of which will set a fault code. Failing sensors will.
I'll assume that the answer to my questions in your other thread is no, so I'm unable to help.
The advantage of your problem is that it is entirely repeatable.
Postby gmg31 » Tue 27.08.2019, 09:52
Simon_P wrote:Your symptoms are consistent with hot coil failure or perhaps leaking injectors. Neither of which will set a fault code. Failing sensors will.
Would Hot coil failure be quite so consistent?
gmg31
Postby HJ2 » Tue 27.08.2019, 11:59
A Leaky fuel injector would....
Postby GeoffSmith » Tue 27.08.2019, 13:03
HJ2 wrote:A Leaky fuel injector would....
That's where my money is!
Postby Simon_P » Tue 27.08.2019, 14:07
Yes but why doesn't it clear after a few seconds.
Easy enough to clear with a hard start.....
Return to Engine
