Tech 1 Scanner tool (Wirral)
Postby ansam » Sat 29.07.2006, 08:26
The engine management part of the manual refers to codes from a TECH 1 scanner. Are these easily available if so from where and how much? I live on the Wirral is there anyone nearby who could show me how such a tool works and test my car for these much referred to and apparently revered errors. Cheers Tony
ansam
Postby ailwyn » Sat 29.07.2006, 10:35
Tony,
The Tech 1 tool is the "garage issue" tool for receiving diagnostic information from the Engine Management System.
Do a search of the forum for Elanscan. This is a windows/pc based software for doing the same job. The software is free and can be downloaded from ESM's (the forum user) website.
In addition to the software you'll need a cable to connect the computer to the port on the car, PM GeoffSmith as he was putting some of these together before, I don't know if he's finished the run yet, or if you can wield a soldering iron, the schematics are also on ESM's website.
Ailwyn
Postby ansam » Sun 30.07.2006, 19:41
brilliant thank you Tony
ansam
Postby Aurora40 » Sun 30.07.2006, 19:46
If you just want to pull codes, can't you do that with a paperclip or short piece of wire? Most GM OBD-I ECM's have a way of doing this, they flash out the codes via the check engine light.
I believe on your cars all you would need to do is connect a paperclip into the rightmost bottom two pinouts (the A and B) of the ALDL and turn the car to the run position.
Again, I don't own an Elan though, so take it for what it's worth (maybe I should change my signature to a standard disclaimer!) :)
What do you get when you combine GM, Lotus, and Mercury Marine? One hell of an inboard!
Aurora40
Postby Monty » Sun 30.07.2006, 21:12
Aurora40 wrote:If you just want to pull codes, can't you do that with a paperclip or short piece of wire? Most GM OBD-I ECM's have a way of doing this, they flash out the codes via the check engine light.
Try this http://lotuselancentral.com/repair/aldl.htm
Re: Tech 1 Scanner tool (Wirral)
Postby Lotus54 » Sun 08.12.2013, 20:33
I know this is a very old thread.
But I recently got a tech2 diagnostics tool.
Is there software avalaible to use with the Elan?
1978 Benelli 750 sei, 1972 Benelli 175 Enduro, 2018 Beta Xtrainer 300
Lotus54
Postby Brit-Car-Nut » Sun 08.12.2013, 22:11
Isn't the Tech2 for OBD2 systems?
Postby GeoffSmith » Sun 08.12.2013, 22:30
Correct, so the hardware isn't even compatible.
Postby Lotus54 » Sun 08.12.2013, 23:59
It is supposed to do OBD1 also, and I thought the Lotus used the tech1?
Maybe there isn't a PCMCIA card for Lotus for the tech2- but I think it comes with an adapter that would plug into the car.
Looks like it anyway.
I was hoping...
Lotus54
Return to Engine
