Elanscan on M chip Mac via VM
Postby NoahR » Mon 29.12.2025, 22:38
Hi all,
I haven't seen anything about this, so I thought I'd let people know. - I've got Elanscan working on my M1 2020 MacBook Air using a VM.
My setup:
* Parallels windows VM on M1 2020 MacBook Air
* Elanscan installed as usual
* FTDI drivers installed. You need to install the Windows versions, but in my case, because it's an M chip, the ARM ones. For those using Parallels, these need to be placed in the Windows C drive, as Windows will not detect the device if you leave them elsewhere.
* FTDI cable drivers set up as usual on Windows.
* Ensure you authorise your computer to pass the FTDI cable through to the VM.
* You will need to install the Windows version of Excel if you want to be able to export to Excel
Thats all. Just thought it might be useful for someone :).
NoahR
Re: Elanscan on M chip Mac via VM
Postby Tuga2112 » Tue 30.12.2025, 09:33
yes, the volvo VIDA software is also provided in a VM format because the setup is particulaly difficult to do.
i find elanscan to be rather trivial. but i can see how a VM option would make life easier to folk less tech savvy.
Postby NoahR » Tue 30.12.2025, 20:34
Tuga2112 wrote:yes, the volvo VIDA software is also provided in a VM format because the setup is particulaly difficult to do.
For me it was more because I don't have easy access to a Windows computer, but I do have a MacBook and as far as I know elanscan won't natively run on mac.
I assume the Volvo interface and the Elan are unrelated?
NoahR
Postby Tuga2112 » Wed 31.12.2025, 12:34
different plugs. and completely different softwares or instalation processes.
but.. related as... "way to see data on the computer from the car" and "awkawrd things to setup"
Return to ElanScan
