how to fit an switchable fan ( under construction GEOFF !)
Postby DeeAitch » Wed 28.05.2008, 18:18
Fitted a 'plug n play' option at the weekend - didn't fancy sticking wires in holes, especially the one shown in the photo :twisted: sorry Clemo :oops:
The connector shown above is pin 86 - at least it is on my car - and if you earth that you will blow fuse A10 which also feeds the ECM IIRC. Maybe a friendly photoshop wiz can put it right?
I hard wired two relays together and simply plugged them in [having removed pin #5 from the AC relay first :wink: ] along with a Carlton fog light switch. This was a pain as the teminal block in the dash was unclipped :evil: You can get to it by dropping the glove box, providing you have skinny wrists, like wot 'er indoors has :-D
BTW the relay bank shown is under the upper dash cover so no need to stand on your head - still a pain to get the fan relay out tho' :evil:
DeeAitch
Re: how to fit an switchable fan ( under construction GEOFF !)
Postby addict » Tue 28.07.2009, 22:40
im having problems getting my cooling fans working . i have earthed the terminal on the thermo housing and with the igniton off the pump runs.
but with the ignition on the fans dont come on. the fuse number 4 gives a live when the ignitions off but no live with the ignition on ..
can anyone be of any help with this issue?
addict
Re:
Postby addict » Wed 29.07.2009, 22:48
paulwatkins wrote:Clemo,
If you remove all the relay units from the board, and undo those two 10mm bolts, you can get to the underside of the fuse-box. No more standing on head in the footwell :lol:
Theres a 30A fuse supplying the load side of that relay. Just be careful that the relay is seated back properly. You dont want any dodgy connections causing a hot junction! Thats how some car fires are started.
and that could be why i have no power to the 2 fans :poke:
addict
Postby addict » Wed 29.07.2009, 22:55
the hand book lists 2 15amp fuses not 1 30amp anywhere
addict
Postby tobyholland » Fri 31.10.2014, 12:49
Hi I followed this to the letter post 85 to earth ignition on ,and I know the fans work but nothing ,, any ideas please
a lotus is for life ,not just Christmas
tobyholland
