Replacement for the Elan aerial
Re: Replacement for the Elan aerial
Postby GeoffSmith » Tue 25.02.2020, 22:19
MarkP wrote:Oh, if anyone needs a mast broken in two pieces you know where to come!
Solder, Araldite, silicone sealant and heatshrink will soon fix that.
Postby HJ2 » Tue 02.02.2021, 20:50
What's the latest word on this?
I ask, because I am in need of a replacement. Either OEM or better (my credo anyway) :-)
Postby peteoddcar » Thu 04.02.2021, 20:36
Hi Chaps
This is just about replacing the the mast !
I ordered one of these more or less out of curiosity. The thread on the OE Bosch is finer than the M4 on this but with careful re tapping the thread in the base I think it would be usable as an alternative. I have the original and a spare for my car but knowing this subject comes up often I thought I’d find a cheap alternative.
https://www.ebay.co.uk/itm/183158591934
peteoddcar
Postby HJ2 » Thu 04.02.2021, 20:44
Better buy one with M5 and cut a new M4 fine thread (you'll need a lathe)
Postby peteoddcar » Thu 04.02.2021, 21:02
Totally
Agreed maybe there’s a group buy opportunity?
I don’t know anyone with a suitable lathe - do you ?
peteoddcar
Postby HJ2 » Thu 04.02.2021, 21:28
Any lathe will do :-)
Postby GeoffSmith » Thu 04.02.2021, 21:54
Even an unsuitable one? :lol:
Postby alan e » Thu 04.02.2021, 22:19
HJ2 wrote:What's the latest word on this?
Hi HJ2 i have sent you a Email.
2010 black evora
Austin 7 1932 box saloon
MG ZS EV
alan e
Postby Simon_P » Thu 04.02.2021, 23:05
I'm not sure what happened to my post, but most likely I forgot to press send!
Anyway, in essence.
I found a suitable aerial some time as ago but it needs an adapter I thought of doing a group buy and that's where it got stuck. So I've got aerials but not adapters. I've got a lathe but this is way too small.
Postby peteoddcar » Tue 09.02.2021, 23:42
I will be getting some adapters made m6 > M4x0.5 which should allow the majority of EBay bee sting type masts to be fitted to the Bosch autoflex base.
I am awaiting for the die to arrive to check I have identified the thread correctly and then I’ll order some brass stud.
I’ll make one and check function then decide how many to make it’ll be a group buy list I guess.
I’ll post again when it’s design is sorted.
peteoddcar
Postby HJ2 » Wed 10.02.2021, 11:39
That's what I do as well.
Sorry, no group buy!
I cut the outer diameter of a wrong adapter (both ends M5) and cut M4 fine then.
Should work!
Postby nicowalker1 » Fri 12.03.2021, 16:18
I'm also in desperate need of a whole unit. Mine was broken whilst the car is being stripped for spraying. The body shop are waiting for me to send one up. Any help/ideas for a straight forward fitting after market? Has anyone used the more modern ones without a mast that I could maybe locate inside the car?
nicowalker1
Postby peteoddcar » Fri 12.03.2021, 18:20
https://www.ebay.co.uk/itm/402466329077
I haven’t actually tried one of these on an Elan. It will need a suitable washer on the underside obviously due to hole size and it will sit not vertical but at an angle. The spacer might need some fettling. If you can bear the look of not upright it might just be a cheap ok ish visually fix.
Does you car still have hole where the original one was ?
I see no reason why a screen type aerial would not work ( provided its active powered ) I think I would put it in the underside of the rear deck area in the boot or even on the boot lid - it’s all glass fibre the further from metal the better.
It might of course be useless, please don’t blame me :bonk: :poke: just trying to be helpful
peteoddcar
