interior lights not working
Postby John Tsakas » Wed 15.06.2022, 17:28
Hello to the group!
My interior lights not working in my new PACIFIC BLUE S2 I bought before 4 months. Can you help ? what i must check first? i already check the fuse in the passenger side, and is ok.
Thank you :cheers:
John Tsakas
Lotus Elan SE British Racing Green 1992
Lotus Elan S2 Pacific blue #125
Lotus Elan SE Monaco white 1993
Lotus Elise S2 Laser blue Touring Pack
Lotus Elan SE Midnight blue 1991
John Tsakas
Re: interior lights not working
Postby FunElan » Wed 15.06.2022, 17:57
This may be elementary....but did you check the bulbs?
FunElan
Postby John Tsakas » Wed 15.06.2022, 19:23
FunElan wrote:This may be elementary....but did you check the bulbs?
:lol: yes i'll check them and we talk again :bonk:
i have also no alarm and central locking
John Tsakas
John Tsakas
Postby exeterjeep » Thu 16.06.2022, 03:31
I also recently acquired an S2 in pacific blue. The original and a second aftermarket alarm system had both failed and been removed. The central locking is driven by an alarm system on S2, will look at another aftermarket alarm system later. Seems that S2's suffer a lot from alarm system failures.
exeterjeep
Postby John Tsakas » Sun 19.06.2022, 13:15
I checked inside the interior lamps and there was no bulbs at all. Unbelievable . Why someone to remove the bulbs :banghead:
So i put new and works fine.
What i must check for the central locking ?
John Tsakas
John Tsakas
Postby MPx » Sun 19.06.2022, 17:16
John Tsakas wrote: Why someone to remove the bulbs :banghead:
Its quite common actually. Many cars suffer a battery drain and its often either the boot light or the interior lights. The boot light because the microswitch moves out of alignment, the interior lights on the mirror because its so easy to turn them on/off when adjusting the mirror in daylight and not notice the light is on. Best answer is to make it right and then periodically check. Second best answer is to remove the bulbs and forget all about it....
Mike - MPx
95 M100 Elan S2 (423)
86 Turbo Esprit
MPx
Postby Saltire » Sun 19.06.2022, 18:47
On an S2, there is no separate central locking (CL) module. The CL is controlled by the alarm, and will not work without it. If you have no alarm, you will either need to fit a replacement one that has integrated central locking (I used a Toad Ai606 T2), or else buy a third party CL system and install that.
Postby John Tsakas » Mon 20.06.2022, 16:32
Saltire wrote:John
MY Alarm it's not working . I saw the black box of alarm under boot lock in the passenger side. I connect it but nothing happen. So maybe thats the problem.
Thanks i am thinking to take the car in my lotus dealer to check it. :burnout:
John Tsakas
John Tsakas
Postby exeterjeep » Mon 20.06.2022, 20:07
John Tsakas wrote:
Saltire wrote:John
I also found the alarm sounder in the engine bay of my S2 but the rest of the system has been removed.
exeterjeep
Postby Saltire » Mon 20.06.2022, 22:19
The OEM S2 alarm sounder is not in the engine bay, so that sounds like an aftermarket unit.
And the OEM S2 alarm control unit isn’t in the boot, so I would say that’s an aftermarket alarm as well. As such, it’s anybody’s guess how it’s been connected up or if it ever worked.
Postby Tuga2112 » Mon 11.07.2022, 15:01
John Tsakas wrote:I checked inside the interior lamps and there was no bulbs at all. Unbelievable . Why someone to remove the bulbs :banghead:
parasitic drain was happening over the halogen bulb, too little current to lit up. but enough to drain battery.
a side result or a poor installation of an aftermarket alarm in my experience with a 98 alfa spider
theory can be tested in 2 ways.
1 - the tipical parasitic drain check (go on youtube and type "eric the car guy parasitic drain")
2 - replace bulb with LED equivalent. if its got light very faint when its not supposed to, you know theres something wrong.
Postby Saltire » Mon 11.07.2022, 20:09
Just a point on Joao (Tuga2112)’s excellent post above. When I replaced my incandescent bulbs with LED four or five years ago, I found it impossible to find an LED for the interior lamps which both has the right cap fitting and is the right size to fit the recess in the interior light. As an aside, that’s why I fitted some extra interior lighting in the footwells. Check the dimensions of the bulbs carefully before you commit to buying :D
Postby Tuga2112 » Tue 12.07.2022, 14:21
Saltire wrote:I found it impossible to find an LED for the interior lamps which both has the right cap fitting and is the right size to fit the recess in the interior light.
I Have had that issue in the past on my 4Runner, I bought a LED panel similar to this listing on ebay with the correct adapter for that specific socket.
a little white tack holding the panel close to the original diffuser and behind that the connection to the bulb.
only problem is. i dont think you will find these small enough to fit inside the small difusers of the rearview mirror. but theres a possiblity something that small exist.
these LED panels are a lot brighter than the halogen bulbs they replace.
