Pioneer Retro Single DIN - might be of interest
Postby AJSGSE1990 » Mon 16.03.2026, 20:21
Just found this and I will install in my car as it looks just right.
https://pioneer-car.eu/sxt-c10ps?fbclid ... 8ZsBunp8Yw
AJSGSE1990
Re: Pioneer Retro Single DIN - might be of interest
Postby Tuga2112 » Tue 17.03.2026, 09:15
certainly looks retro.
have you looked at blaukpunt (im probably spelling it wrong) units ? they have a few different retro looking ones last time i checked.
a retro looking radio is one of those many tasks that is in my todo list for when i retire.
the plan is to take a non funcitoning unit that was originally fitted in the car and use the case and buttons, while swapping everything else for modern tech...
one day :roll:
Postby AJSGSE1990 » Wed 18.03.2026, 07:57
Tuga2112 wrote:the plan is to take a non funcitoning unit that was originally fitted in the car and use the case and buttons, while swapping everything else for modern tech...
one day :roll:
I've done that for a normal household amplifier, it's not super complicated except for rotary switches. You can buy quite effective and cheap "mechless" units which are half depth single DIN and use a USB extender to hide the port somewhere else.
Rotary ones you either have to be lucky, and the resistance range is similar or if stepped that it works on the same pins. If not, you are going to have to use the unit from your donor device, which might or might not fit in the case. This is where it gets difficult.
For car use; soldering the button extensions from the donor to the original PCB will take a lot of patience and precision, once it works, I would recommend sealing it (the PCB surface) with a resin dip. This should help the joints breaking from vibrations.
AJSGSE1990
