by GaryJ » Sat 23.07.2005, 10:59
Have lost ALL electrics now on my Elan. The engine will crank over but obviously not start due to this. Any advice or does anyone know a good sparky round the Redditch / Bromsgrove area, please??
The really annoying thing is that it was going in to have it's full service and cambelt this morning!
GaryJ
by rob » Sat 23.07.2005, 11:24
just a guess but have you tried all of the earthing posts to make sure they are ok. To loose all the electrics must be more than a fuse, and as the starter motor will be earthed on its own i would give this a go first.
Good luck
rob
by GaryJ » Sat 23.07.2005, 11:36
Sounds worth trying. Where are they Rob? I did check all the fuses including those under the binnacle cover thingy just to make sure.
GaryJ
by ESM » Sat 23.07.2005, 12:52
Have you checked the maxi fuses?
ESM
by clemo » Sat 23.07.2005, 13:09
to get to the maxi's remove your stereo .
then its a black cover (about the size of a box of 10 fags)
on it side with a catch at one end...
big fuses in there..
clemo
- LEC Administrator
- Location: TORQUAY Devon. Cream first then Jam obviously.
by GaryJ » Sat 23.07.2005, 13:10
I don't think so but I will now. Call me stupid but I can't make out the pic too well as to where these fuses are located.
GaryJ
by GaryJ » Sat 23.07.2005, 13:18
Thanks Rob, ESM and Clemo for the advice. I will give these a go tonight and try not to break anything! I always seem to break something the more frustrated I get!
It certainly looks a good option so I will keep you posted.
GaryJ
by clemo » Sat 23.07.2005, 13:20
gary sent you my phone number twice but not showing in my sent items ..
have you got it?
clemo
- LEC Administrator
by GaryJ » Sat 23.07.2005, 13:30
Yes Clemo I have. A very kind offer. I have sent you IM.
GaryJ
by GaryJ » Mon 25.07.2005, 15:13
Ok. Checked all the fuses and they are all fine. I am at a bit of a loss!
GaryJ
by Neil D. » Mon 25.07.2005, 15:39
What alarm system do you have, and is there a ignition cut off switch.
Or have you tried the fuel pump cut off.
Unlikely as you say you have no electrics but cranking
Strange
Neil
Neil D.
by GaryJ » Tue 26.07.2005, 08:55
Clifford immobiliser. This is my guess as well now as to what is causing this.
The only electrics that do work are the ones that do not require the ignition to be on i.e. hazards and lights.
Hopfuly my sparky will fix.
GaryJ
by GaryJ » Mon 08.08.2005, 13:27
Bump
Still struggling here. Can't get an electrician to come out and don't really want the car taken away on a flat bed for fear of damage. B0llocks.
GaryJ
Users browsing this forum: AhrefsBot and 1 guest
