Full Exhaust Quote/ Possible Group Buy
Re: Full Exhaust Quote/ Possable Group Buy
Postby Monty » Sat 23.04.2005, 11:27
Monty and Dico, you guys have confused me a bit, i have quoted for the exhaust to start from the precat back, as in take the precat off and then start the exhaust, is that what you thought ? The other thread about the precat replacement is changing the piece above this too i believe ?<br>
<br><br>Steve, your right, were after replacing the precat and the whole exhaust. When stevo started his thread he was just doing the precat but now he`s doing the other bit which goes to the back of the turbo (like the one Sy had made up) which i`m not to bothered about. Need to keep price down as i`ve ordered the Wilwood brake upgrade so i`m in to my overdraft  ::)
Postby Monty » Sat 23.04.2005, 12:02
Yep u`ve got it, it`s all down to the flanges, i would think that the blokes doing steve`s exhaust system will just have one flange which will go to the manifold/turbo, cause less flanges the better for the keeping cost down. unless paul u state to steve that u just want u`r system up to the precat, so u could fit Stevo`s part, but u would have to make sure there going to fit. Thats why i`m just going for Steve`s system, just keep it simple.<br><br>Hopefully Steve`s system should look like this, (poor nige his picture gets about LOL)<br>Image<br><br>Steve, if the exhaust place doesn`t give a garantee with the unfitted version, we would want it quite a bit cheaper for a cash job ???
Postby Monty » Sat 23.04.2005, 12:58
Nope i am thick, just got better imagination  :P  ;D<br><br>I certainley don`t need enemys with mates like u  ::)<br><br>Maybe it`s cause u`r head is full of wedding s**t rather than scotch trip LMAO  :)
Postby Paul.P » Sat 23.04.2005, 14:02
Wonder if the alcohol could have something to do with it  ???
Postby timhagger » Sat 23.04.2005, 17:06
My gearbox/bearing is making a bit of a nasty noise...whats this got to do with it you might ask?.<br><br>Well depending on how much the gearbox problem is I will be up for replacing my current 2.5" system. <br><br>I'm probably the closest to ashford than any of you so I'm happy to volunteer my S2 to go in for the initial fit. I could also show the guys what we don't want by showing them the current "drainpipe with squishes" that is attached underneath my car! <br><br>Reason I volunteer is that timescale wise I can probably do without the car for a week or so (benefit of being home office based!). Anyhow the offer is there steve, and if you want to meet up with the guys in ashford just let us know...<br><br>Oh yeah, that makes it 6 possible exhausts I guess - so we'll get the price down some more  ;D
timhagger
Postby Avonvilla » Sat 23.04.2005, 17:35
Paul, i got the impression they will make them all at the same time and test fit them to my car so they will all be identical. Easy fit for a garage or even at home for some braver than me !<br><br>Monty, OK mate were on the same ball park  :) that pic is exactly what it should be like  :)<br><br>Dico, theres no way the 2 will be comaptiable, if you go for Stevo's you would have to then have a custom fit from that back although this will be easier to get done as it's the precat thats the tricky bit.<br><br>Timmay, so you would want the same as me a full system with high flow cat ? I'll bear all that in mind cheers.
Avonvilla
Postby timhagger » Sat 23.04.2005, 18:21
Yep - full system, remove precat and custom fit flange to 2.5" all the way back, high flow main cat, backbox, the lot :)
timhagger
Postby Avonvilla » Mon 25.04.2005, 02:04
Right had a reply today which is something  :)<br><br>Hi Steve<br><br>yes price can be off putting but as you say no more exhausts to buy at the end of it.<br>yes first piece will have flexible joint <br>right first with cats would be for 2 off £790 + VAT each saving of £60 +VAT <br>without cats 3 off £480 each +VAT <br>front cat elimination pipe including flex can be jigged if there is sufficent orders<br>no problem costing would approx be £130 to make dependant on quantity<br><br>hope this helps<br>Regards dave<br><br><br>As previously said the cat systems are quoted fitted and the se ones not.<br><br>Thoughts ? my brain hurts lol
Avonvilla
Postby Monty » Mon 25.04.2005, 13:52
Still sounds expensive especialy if thats with a group discount.  ::) does that include life time garantee?<br><br>
<br><br>Steve as the above quote says with out cats, does that price not include the precat replacement  ???
Postby Avonvilla » Mon 25.04.2005, 17:49
Monty thats for a full system as in the first post just no main cat so a through pipe instead and a pre cat eliminator included.<br><br>£480 plus vat seems great to me as paul mattys is £400 plus vat and thats only 2.25" and no precat piece at all !
Avonvilla
Postby Paul.P » Mon 25.04.2005, 20:01
Wonder if they would waver the vat for a cash deal ?, that would make it a reasonable price !
Postby Monty » Mon 25.04.2005, 20:08
Would think PM would have his exhaust made up by someone else and he will put his cut on top. U`r dealing with the Exhaust place direct, just doesn`t sound like u`r getting a big discount considering there`s a possible order for 6  ??? and if there`s no garantee then its way to expensive. think most of us was hoping for less than £500 with out fitting. I`m all confused on what to do ::)<br><br>What do u other guys think? Dico. Paul.P.
Postby Avonvilla » Mon 25.04.2005, 20:09
Yeah i wondered that, once we get a final order together i'll ask em on that too  :)
Avonvilla
Postby Monty » Mon 25.04.2005, 20:09
[quote author=Paul.P link=board=exhaust;num=1113504212;start=45#52 date=04/25/05 at 12:01:47]Wonder if they would waver the vat for a cash deal ?, that would make it a reasonable price ![/quote]<br><br> [smiley=agree.gif]
Postby Avonvilla » Mon 25.04.2005, 20:15
Monty dont really see your point ? it's £80 more for a full 2.5" as opposed to 2.25" and you a precat eliminator ? For this kind of equipment what are you comparing the price too ? i'm confused ?<br><br>
Avonvilla
Postby Paul.P » Mon 25.04.2005, 20:15
Monty has got a point there, PM does get his exhausts from outside supplier, so he will be putting his cut on it, don't think im being negative, but i do think, if you mention Lotus these suppliers just up there price, in my opinion £480 is quite enough for what were getting as once theve made one, the others should be easy !
Postby Avonvilla » Mon 25.04.2005, 20:17
Sorry guys i really dont see your points when not comparing like with like !
Avonvilla
Postby grahamec » Mon 25.04.2005, 20:17
Scuse me for sticking my nose in but with all the talk of costs I thought I would tell all how much mine cost and therefore give you all another benchmark<br><br>2.5"<br>Pre cat left in place but hollowed out<br>New down pipe from pre cat<br>New flexi joint<br>Main cat swap pipe<br>2 new silencers<br>3.5" s/s tail pipe<br>Fitted<br><br>£500 + vat<br><br>Hope this helps in your ponderings
grahamec
Return to Exhaust
