SE OEM Exhaust removal - quick question
Postby Gordon » Sun 11.04.2010, 17:54
Just a quick question so I can decide how to tackle a little problem!
I need to remove the front section of the main exhaust - The first section AFTER the downpipe (flexi/sprung joint).
I'm happy that I can seperate both joints, my question is do I need to remove the subframe/prongeron in order to get the section off?
If the Progreron has to come off, it makes a big difference to me as to how I'll tackle the job!
TIA,
Gordon
1990 M100, Calypso Red
2005 Vectra C....
Gordon
Re: SE OEM Exhaust removal - quick question
Postby tonny006 » Sun 11.04.2010, 19:02
Gordon wrote:Just a quick question so I can decide how to tackle a little problem!
TIA,
Gordon
No you don't,
It comes out quite easily.
Good luck!
Tony
tonny006
Postby Gordon » Sun 11.04.2010, 19:40
Thanks Tony - I'll give it a go...
The front flange of the flexi joint looks very tight to get to with the subframe in the way...
I assume there's an olive in the middle of the joint?
Gordon
2005 Vectra C....
Gordon
Postby tonny006 » Sun 11.04.2010, 19:42
Gordon wrote:Thanks Tony - I'll give it a go...
Gordon
Yep,you guessed right.
Tony
tonny006
Postby dapinky » Sun 11.04.2010, 22:20
In order to make it easy, there has to be a reasonable ground clearance - preferably up on a ramp - but failing that, then get the front up as high as possible so that you can get the angle to manoevre it round the subframe.
Postby Gordon » Mon 12.04.2010, 08:21
I got the flange disconnected OK, but there is no clearence to slide the pipe forward to clear the sleave joint to the centre section :shock:
I guess I'll have to drop the subframe - no big problem, just wanted to avoid if possible...
Gordon
2005 Vectra C....
Gordon
Postby Gordon » Mon 12.04.2010, 11:23
Does anyone know if SJ's stainless front pipe SJ100S0004 will fit to a standard OEM steel centre pipe?
2005 Vectra C....
Gordon
Return to Exhaust
