after market CAT
after market CAT
Postby norman lovie » Wed 29.08.2012, 18:55
anybody with experience of fitting a sports CAT after the down pipe ? did it suffice to meet the MOT reg's ?
norman lovie
Re: after market CAT
Postby j700tus » Thu 30.08.2012, 17:29
I have a 96 S2 and have recently fitted the piper kit including sports cat and it passed the Mot just fine! The pre cat is still fitted and is the original one. Hope this helps.
Paul
j700tus
Postby Robert_P » Mon 17.09.2012, 14:13
My experience with replacement Cats is that as long as the Cat is defined as a 'direct fit and OEM replacement' there should be no issues with how it performs, and even fewer with how it fits and installs. Eastern Catalytic manufactures replacements that meet the performance of OEM. Rock Auto sells them.
Robert_P
Postby GeoffSmith » Mon 17.09.2012, 14:51
norman lovie wrote:anybody with experience of fitting a sports CAT after the down pipe ? did it suffice to meet the MOT reg's ?
If your car was registered before 1/8/95, then you don't need a cat but it might make passing the MoT easier!
Postby DeanG » Thu 20.09.2012, 00:39
Here on the left side of the pond I have been using replacement cats for several years. After the original died I had a local shop replace it.
DeanG
Return to Exhaust
