hi ,exhaust info please
Postby tobyholland » Sun 05.01.2014, 19:53
Hi all
I am after two stainless pipes ,they are the two middle ones out of the four sections ,my car only has a box on the rear,
Any ideas where they can be purchased, preferably from an UK exhaust manufacturer ,
Toby
a lotus is for life ,not just Christmas
tobyholland
Re: hi ,exhaust info please
Postby chrisP » Thu 09.01.2014, 14:15
It all depends on your current system and whether it is OEM or aftermarket?
chrisP
Postby tb10 » Thu 09.01.2014, 16:38
I went to swap the back two sections from my wife's Elan to my Elan as she said her exhaust sounded too noisy. I then found out that they were two completely different exhaust systems so she's still got the noisy one :lol: :burnout:
tb10
Postby Jeemy » Thu 09.01.2014, 21:12
If you can measure the diameter of the pipe, likely 2", 2.25", or 2.5" (2.25" most likely on a stainless system) that will help with advice. Piper and Peco are the two usual suppliers of aftermarket SS exhausts, but I am not sure if there are differences in the pipe lengths which would make one system incompatible with another.
If you can get the pipe diameter and the length of the pipes, both easily measurable from underneath, then you should be able to source the exact part from one of those two, SJ Sportscars, Paul Matty or eBay.
PC+1
T: 0800 084 3084
M: 07391 295 146
Jeemy
Postby Fredjohn » Thu 09.01.2014, 21:55
In addition to Piper and Peco, there is also Powerflow who do stainless exhausts. Both 2.25" and 2.5"
http://www.powerflow.co.uk
Worth a look anyway :D :D
Postby tobyholland » Mon 13.01.2014, 19:22
ah thanks for that info lads.
I thought the were the same , so that helps a lot
thankyou
toby
tobyholland
Back stainless box query
Postby tobyholland » Tue 20.05.2014, 13:47
On the back box of my old stainless exhaust it is joined to short section of mild steel,, I have seen others similar is this normal and is it for a reason
Toby
tobyholland
Return to Exhaust
