Available options to silence Peco (Cybox) exhaust
Postby HJ2 » Fri 19.05.2017, 10:50
Dear all,
I just bought a house with a garage in a rather friendly neighbourhood / community.
As a 'gift' to the new neighbours, I would like to silence my Peco exhaust a bit.
Does anyone has some experience with this and know what options are available?
Re: Available options to silence Peco (Cybox) exhaust
Postby GeoffSmith » Fri 19.05.2017, 11:39
GBP1:
GBP78:
PNMS9002ES
Postby HJ2 » Fri 19.05.2017, 13:18
But will it fit with the standard 2.25" peco system?
(Not the earbuds, duh!) :lol:
Postby GeoffSmith » Fri 19.05.2017, 13:50
Yep. Fitted one on mine a couple of years ago. To be honest, I don't think it made too much difference to the neighbours but now it's sooted up it takes the edge of the booming at high speed.
Postby HJ2 » Fri 19.05.2017, 14:08
Then that's even better as the boom is annoying :evil:
I'll order straight away! Any LEC Discount?
(Hmmzz.. Now I need to order an uprated oil cooler as well to compensate for the loss in power :lol: )
Postby John_W » Fri 19.05.2017, 15:51
Another option is to get your local exhaust fabricator to insert an additional silencer in the "up" bit of the exhaust in the right wheel arch, just ahead of the wheel. The attached photo should show the position.
I have been running with this arrangement (2 1/4" stainless exhaust) for over ten years. It is still not as quiet as the standard system, despite the fact that I had the additional silencer replaced by a larger version last year before a long european trip (3,500 miles) to reduce the booming.
The attached picture is from 2005 during the initial fitting, and shows a cylindrical silencer. The current additional silencer is oval in cross-section and larger (but I don't have a picture of it).
Postby HJ2 » Fri 19.05.2017, 16:54
The thing is... I don't trust these local Guy's. I'd rather buy something that I can install myself :wink:
Postby lolaman » Fri 19.05.2017, 17:32
I have bought one of these as an additional silencer for the stringent noise limits at Castle Combe next weekend.
https://www.merlinmotorsport.co.uk/s/ex ... d-mufflers
Click on the third illustration.
1968 Elan S4 DHC
1968 MGC Roadster
1990 Elan SE - Sold
1978 Lola T580 - Sold
lolaman
Postby alan e » Fri 19.05.2017, 20:44
PNM do a extra box for the peco exhaust I have fitted one to my system.
2010 black evora
Austin 7 1932 box saloon
MG ZS EV
alan e
Postby HJ2 » Sat 20.05.2017, 08:50
Top tips!
And what are your experiences with an additional silencer? Was it worth it? :mrgreen:
Postby alan e » Sat 20.05.2017, 10:32
GeoffSmith wrote:Yep. Fitted one on mine a couple of years ago. To be honest, I don't think it made too much difference to the neighbours but now it's sooted up it takes the edge of the booming at high speed.
2010 black evora
MG ZS EV
alan e
Postby John_W » Sat 20.05.2017, 13:06
It was worth it, but I'd like it quieter.
When driving, my current system is noticably quieter than a big bore straight-through stainless steel system without the extra silencer, and the "droning" noise (which I found wearing on a journey) is almost gone. However, idling is not as quiet as I would like. You definitely know the engine is running.
Postby HJ2 » Sat 20.05.2017, 13:11
that sounds perfect then!
I also thought of replacing the front rubber hanger (is this the correct term) for a softer one, as I believe that most of the droning comes from here
Any opinions on this, or a link to a supplier for softer hangers? The rear hanger cannot flex so much for a reason, but I think it is viable to replace the front...
Postby Graaf » Sun 21.05.2017, 15:17
I fitted the PNM (Peco) to my Elan and it sounds fine. Nowhere near as loud as the larine was on my Elise and I thought that that was relatively quiet. I'd be surprised if it upset the neighbours.
Graaf
Postby HJ2 » Sun 21.05.2017, 15:26
Then perhaps you still have the OEM downpipe and the pre-cat still in position?
Postby Graaf » Sun 21.05.2017, 19:59
HJ2 wrote:Then perhaps you still have the OEM downpipe and the pre-cat still in position?
Ah, yes!
Graaf
Postby HJ2 » Tue 08.08.2017, 08:52
Any new opinions on this matter?
I am about to move to a new neighbourhood in 3 weeks and I still intend to buy an additional second silencer as a gift for the new neighbours :-D :-D :-D
It is either the PNM option on the second silencer or replace the current (2.25") PECO silencer with a piper, PNM or alternative one...
The aim is to silence the car a tad and to get rid of the droning... No pointers to softer hangers anyone?
Postby Rambo » Tue 08.08.2017, 09:21
Don't go down the Piper or PNM route then as personally I have found that they are as loud and boomier as the Peco. Believe me, I have both and love the throaty rasp :wink:
If I were you I'd just let the engine tickover and creep past in 1st gear
Then when you've passed the neighbours, floor it :burnout:
Sorted :wink:
Postby HJ2 » Tue 08.08.2017, 09:28
Well... On a cold engine the idle is the loudest part that i (or the neighbours) want to get rid off...
I drive off with clutch only and don't use the loud pedal at all!
Thanks for the tip not to exchange the entire system as in your experience it will bring nothing! :)
Postby Rambo » Tue 08.08.2017, 09:32
I suspect the way to go is the extra silencer. I think you can get one from Peter Musgrove at PNM Engineering. Worth a phone call to discuss your options with him anyway
Return to Exhaust
Users browsing this forum: SemrushBot and 5 guests
