Mounting point weakness
Postby Avonvilla » Sun 04.09.2005, 16:13
I've read a few times that there is a place where the downpipe mounting breaks because the stock setup can be too rigid ? i have a annoying rattle all of a sudden and wanted to know exactly which bit to look at to see if thats my my problem ?
Avonvilla
Postby Doug » Sun 04.09.2005, 16:26
my downpipe broke at the top flange, which is the weak point--the system is rigid and as the engine rocks and rolls, this flange takes the stress and breaks! This breakage would be accompanied by a noticably louder exhaust sound though . . .
Postby Avonvilla » Tue 06.09.2005, 01:49
Thanks Doug
Avonvilla
Postby Doc Fizzix » Tue 06.09.2005, 05:39
Doug wrote:my downpipe broke at the top flange, which is the weak point--the system is rigid and as the engine rocks and rolls, this flange takes the stress and breaks! This breakage would be accompanied by a noticably louder exhaust sound though . . .
I have an extra down pipe, do you think if I put an extra beed of weld around the top flange that would help any? Or does it not matter because it is still a weak point? Thanks
Doc Fizzix
Postby Doug » Tue 06.09.2005, 05:47
i bet it would help -- it may then be strong enough that something else becomes the weak link. . .
best thing to do is incorporate a short length of flex-pipe in your replacement exhaust system and then it won't stress the joints.
Postby Doc Fizzix » Tue 06.09.2005, 20:21
Doug wrote:i bet it would help -- it may then be strong enough that something else becomes the weak link. . .
Thats the way it always works, you just move the weak point to something else :wink:
Doc Fizzix
Return to Exhaust
