Paul Matty exhausts
Paul Matty exhausts
Postby greg » Mon 16.02.2004, 11:03
Hi All,<br><br>My exhaust is now in two incompatible parts so I need a new one.<br><br>Rang PM, and a parts chappy said they did fit only.  Which will not work as my car is in sussex, they are near Birmingham, and my exhaust is very loud!<br><br>Their objection seems to be that it is very difficult if fit and requires custom work (with hear apparently).<br><br>Has anyone had or fitted one of these themselves, ie not using PM fitting service.<br><br>I need to get my car fixed.<br><br>Thanks
greg
Re: Paul Matty exhausts
Postby Richard_A_Clifton » Mon 16.02.2004, 11:06
PM will supply the Double S system (or parts thereof).
1990 BRG M100 Owned from new 245,000 miles
1991 BRG M100 Owned since 2025 210,000 miles
1967 BRG Elan S3 S/E Owned since 1982
Richard_A_Clifton
Postby Sy V » Mon 16.02.2004, 15:06
I think Dave (IIRC) fitted his own PM sports exhaust.
Postby greg » Mon 16.02.2004, 15:16
US based Dave?<br><br>My Mechanic and Roy from PM are hopefully having a chat now.  My mechanic seems not too keen to fitt it due to the "Custom" nature and the possible need to heat it to bend it into shape
greg
Postby Sy V » Mon 16.02.2004, 16:12
No, Dave from T&W.
Postby A6LANMAN » Mon 16.02.2004, 21:07
I fitted the SJ sports exhaust system myself. It was a real pain but only because I am not a mechanic. If you can't persuade PM to sell one, SJ certainly will.<br><br>Good luck.
A6LANMAN
Postby DeeAitch » Mon 16.02.2004, 22:20
Dave from T&W? Yep that's me :D<br>There is lots written on this forum about the sports exhaust from PM - a search should find most stuff.<br>PM will sell you "supply only" but only if you promise not to call every 1/2 hour to complain ;) They resist for a reason!<br>The following is a summary of my experiance - it is posted somewhere else on this forum but I can't find it. Sorry to repeat it as it caused some adverse reaction the last time - items 7 & 8 that is ;D<br><br>"Recently I got the chance of a Paul Matty "Sports" Exhaust system "on the cheap", well what would you do? <br>PM were VERY reluctant to sell this "supply only". They stressed it is a sod to fit and boy are they right! Without a lift you will curse! They also suggested further engine mods would be neccesary to prevent boost creep. <br>Some points to note: <br>1. It is not 2 1/2". The centre and muffler tubes are 2 1/4" (57mm) with the "front" having a prominant squished section which is really far to long IMHO (It is not really a front, this is not supplied. It is the Squished pipe aft of the spherical joint) <br>2. The spherical joint flange is too small. It does not fit the seal very well which in turn is 0.5mm too small for the stock front. <br>3. The spherical joint flange is at the wrong angle to mate with the stock front. Difficult to get a good seal. <br>4. The centre comes very close to the front chassis hanger bar, actually mine touched. <br>5. The Muffler does not sit in line with the car, this results in the tail pipe being angled out, very boy racer-ish! You will wonder what they were thinking of. It would have been so easy to get this right. <br>6. The muffler hangers did not come even close to the correct positions. The rear on mine needed re-bending 1/2" and I had to source some revised rubbers to get the tail pipe to sit centrally in the bumper (fender?) <br>7. It is LOUD! I am getting too old for this loud, especially as I thought the stock (OES muffler) sound quality was good. Sound quality is actually very good, just too loud for my taste. <br>8. The car does seem to fly now. Maybe it is the noise making it sound fast. Doubt if it is giving as much as 40 BHP as some claim tho', especially when you see the squished front.<br><br>These comments apply to my system. Obviously manufacuring tolerances mean I may have got hold of a particullarly bad example. Also the above is in no way negative towards PM, they are a great bunch of guys. As I said they were not happy supplying this system and it is everything they described (apart from 2 1/2" that is). Out of interest the system is made by "Milltek" who can be found on www.milltek.co.uk "<br><br>Elanscanman has seen & heard mine. Any comments Alan?<br>
DeeAitch
Postby Sy V » Tue 17.02.2004, 08:54
Dave<br><br>Apart to confessing that PM's mechanic who fitted mine last year said that some are easy, some aren't and mine was an absolute b1tch to fit!  <br>I'll have to balance your query to Alan with...<br>Rob's seen and heard mine, any comments Rob?
Postby greg » Tue 17.02.2004, 10:12
Thanks Dave.<br><br>Keep um coming.   Need to chase my Mechanic to see if he will fit it!
greg
Postby DeeAitch » Tue 17.02.2004, 20:30
Sy<br>It seems strange we both have systems that were b1tches to fit :-/<br>Can't believe they can make them such a bad fit - it must be fairly easy to make a simple fitting jig from an OE system.<br>I guess PM are sick of fending off irate customers hence their reluctance to sell "supply only".<br>As Rod says elsewhere, noise is subjective. Lots seem to love it :D <br>I can only suggest that anyone tries to hear before they buy if possible.<br>BTW does this explain your 205bhp? Rod also shows 40bhp gain but I'm not sure if this is combined with 14.5psi
DeeAitch
Postby Sy V » Wed 18.02.2004, 14:17
It's certainly a large contributory factor.<br>I'll revert to my standard signature block at the w/e and you can see the list of other mods.
Postby timhagger » Thu 19.02.2004, 12:57
I know that milltek are good but has anyone had experience of powerflow exhausts - they seem to "specialise" in making exhausts to your needs....
timhagger
Postby greg » Thu 19.02.2004, 13:07
I've ordered one now ::)<br><br>Should have the car back on the road next week!<br><br>Thanks for the feedback.<br><br>Not used them but powerflow are supposed to be quite good.
greg
Postby Philbo » Fri 20.02.2004, 11:38
[quote author=Dave link=board=help;num=1076925806;start=0#6 date=02/16/04 at 13:20:05]Dave from T&W? Yep that's me :D<br>8. The car does seem to fly now. Maybe it is the noise making it sound fast. Doubt if it is giving as much as 40 BHP as some claim tho', especially when you see the squished front.<br>[/quote]<br><br>Just like to say that I have the dyno charts to prove *my* 40bhp gain - but then I was running the stock system absolutely maxed-out at the time. Everyone's mileage will vary of course - but *I* did get +40bhp. At the top end of the rev range - feck all extra below 4500rpm - hence the mods that followed...<br>
Philbo
Postby DeeAitch » Fri 20.02.2004, 18:24
Knew I should have left No 8 out :-X<br>I have your Dyno charts Philbo - got them off you last year. One of the reasons I went for it at the time. I show them to all my friends when they ask why it is so loud 8) Hope you don't mind :-[.<br>I have no reason to doubt the figures you have, maybe it is because you have 2 1/2" ;) - only kidding.<br>What do you mean by "stock system maxed out" do you refer to boost? <br>Was the BBR fitted later? <br><br>BTW Sy did Elanscan also show 205?<br>Dave
DeeAitch
Postby rob » Fri 20.02.2004, 20:21
<br><br>LOL  [smiley=Up_to_something.gif]
rob
Postby Sy V » Fri 20.02.2004, 22:05
Dave<br><br>I was told last night that Elanscan showed 412 BHP.<br>Shall we go with the graph?
Postby DeeAitch » Sat 21.02.2004, 01:01
Graph it is! Unless TreVoR is asking ::)
DeeAitch
Postby Sy V » Sat 15.10.2005, 15:20
Found this thread as the very last one in the section, so now it's revived.
Talking to PM this very morning and he let slip that he's having a new exhaust built. His main concerns were the laborious nature of the fitment.
I gave him the lowdown on owners'/viewers' feedback in that 'generally' people liked the tone and sound of the exhaust and those lovely overrun pops that you can get, but that the main dislike was the fact that it looks like an aftermarket part because of the angle at which it protrudes, at the rear.
He had not had this said to him before and I took him to see mine and another customer's Elan which had the South West exhaust fitted.
He promised to address the problem in this new build.
Postby Monty » Sat 15.10.2005, 17:07
Sy,
did u tell him to do away with the squish too :roll: otherwise it`s cheaper to have a custom exhaust done :?:
Return to Exhaust
