Head removal
Head removal
Postby tb10 » Mon 02.07.2012, 12:37
Does anyone know what size hex socket is required to remove the head bolts? The space is quite tight and it appears a normal length 1/2 socket will not fit.
tb10
Re: Head removal
Postby tb10 » Fri 20.07.2012, 14:30
Anyone??
tb10
Re: Head removal
Postby Brit-Car-Nut » Fri 20.07.2012, 16:51
I would assume all the bolts on the engine are metric, so be careful trying to use imperial tools.
Re: Head removal
Postby addict » Fri 20.07.2012, 17:18
they have a habit if using odd sizes 11mm 14mm 18mm ect but all metric buy a good metric socket set and a deep metric socket set as well would be a good idea
addict
Re: Head removal
Postby HJ2 » Fri 20.07.2012, 19:15
It's all plain metric indeed!
