by m100sandra » Mon 23.07.2012, 01:15
A really short message just to ask for help re: my side window which is stuck in the down posistion
The glass when it trys to come up isnt straight (hope that makes sense) im guessing that its maybe come off the window rail or somthing?
Any tips please for the fix, im guessing the int door panel will have to come off? if so is it a easy job?
Sandra
m100sandra
by hatters » Mon 23.07.2012, 10:02
No its not an Easy job its an absolute pain in the arse, Good luck ,There is a fix on here somewhere . make sure you have the required butterflies and orange clips before you start because they will be broken or they will break when you strip it down
hatters
by rip » Mon 23.07.2012, 10:46
Does it move at all?
My passenger window used to stick halfway when I bought the car. This was simply because it never got used. I cured it just by using it regularly
My driver's side used to go up unevenly (& still does a little even after rebuilding). I usually push up the rear by hand gently when winding up.
by Specky » Mon 23.07.2012, 14:22
m100sandra wrote:A really short message just to ask for help re: my side window which is stuck in the down posistion
Sandra
PM me if you would like to talk it through (I'll send you my number) most of the window issues are easy to rectify, but only if you know what you're doing.
If you're at a total loss then it can take days.
by m100sandra » Mon 23.07.2012, 21:54
Thanks for the replys, It will come up a bit, maybe 4" at the front and level at the back and then just jam, iv had a search on here but cant find anything that resembles instructions re: taking the int panel off etc
Help,
Sandra
m100sandra
by Greggry » Mon 23.07.2012, 22:13
Mines done it on the passenger I took it to a garage and he can't do it!! Wtf!!
I'm guessing the regulator??
Greggry
by hatters » Mon 23.07.2012, 23:39
My O/S one is exactly the same and my N/S one hasn't worked since I had the car
If you grab hold of the back of the window whilst you are operating the switch and give it a pull it should come up O K .The windows are the achilles heel of the Elan crap to say the least !!
hatters
by Specky » Tue 24.07.2012, 09:53
m100sandra wrote:Thanks for the replys, It will come up a bit, maybe 4" at the front and level at the back and then just jam, iv had a search on here but cant find anything that resembles instructions re: taking the int panel off etc
Help,
Sandra
There's a very good chance you'll have a pre- mod Main slider which has sheared at the normal place. This cants over at about the 4" point, which in turn jams on the rail and cants the window over. It's 2-3 hours to undertake the task. This is where you need to know what your doing or you'll turn a simple task into a 2-3 day task. Cost to rectify.... about a tenner... If you utilise someone who doesn't know Elans... You'll be talking hundreds, mainly in labour charges.
by m100sandra » Tue 24.07.2012, 23:05
Ill ask my other half to have a go at the w-e, I think im really putting him off the Elans now
Ive just picked up the link on the other similar post which should be a help,
What is the actual fix presuming its the: pre- mod Main slider which has sheared at the normal place. Any help appreciated
Sandra
m100sandra
by Specky » Wed 25.07.2012, 07:45
viewtopic.php?f=32&t=12738&start=20#p202892Today I'm going to overhaul a unit for Gregory, so I'll do a full write up because the information for undertaking this task is now in several areas...
I'll try and post the finished article before the weekend.
If you require any help don't hesitate to drop me a PM.
by bobbrown » Wed 25.07.2012, 08:46
As a side note, I had a problem with my near side window and could not get it to run true so left it up disconnecting the motor thinking I'll have another crack at that. Well 2 years later I did when I was doing the inner sills, or at least connected the motor to see if it still had the same problems and low and behold it worked fine, nothing had be changed since I cleaned all the runners and replaced the centre slide and butterfly. I think it may need some friction in the center mount (butterfly) to hold the glass in position but not sure as I did not look any further as it was working.
Pacific Blue N/A
