by GoM100Go » Fri 21.09.2012, 03:29
My Élan has developed a strange turbo needle behavior. I know the turbo in not running because I am at a complete stop and the needed bounces wildly with a smoothly idling engine. It will lay flat then without provocation bounce straight up
it even goes wild on the turn of the key without the engine even running
My turbo is boosting strong and at appropriate times when I "ask" for it, my blow off is appropriately releasing. I may have a gremlin living being my turbo gauge. :-/ Any ideas to begin getting that thing out?!?! Thanks.
-James
James
2009 Range Rover Sport HSE (Storono grey)
1991 Lotus Élan (Calypso Red)
GoM100Go
by esprit888 » Fri 21.09.2012, 07:54
Remove clean and reinstall the wires (in particluar the ground ) going to the turbo boost transducer located on the left strut tower as you look at the engine (kinda orange/brown looking cylinder) 99 times out a 100 thats the problem
GoM100Go wrote:My Élan has developed a strange turbo needle behavior. I know the turbo in not running because I am at a complete stop and the needed bounces wildly with a smoothly idling engine. It will lay flat then without provocation bounce straight up
-James
esprit888
by rip » Fri 21.09.2012, 09:14
esprit888 wrote:Remove clean and reinstall the wires (in particluar the ground ) going to the turbo boost transducer located on the left strut tower as you look at the engine (kinda orange/brown looking cylinder) 99 times out a 100 thats the problem
by GoM100Go » Tue 25.09.2012, 05:30
Thanks, I will try it tomorrow!
James
GoM100Go
by GoM100Go » Tue 02.10.2012, 02:22
Wow, that has to be the easiest fix ever. It's back to normal behavior...
James
GoM100Go
