hand brake cable
hand brake cable
Postby barefoot » Thu 07.03.2013, 11:33
Is there any instructions or guides for replacing the hand brake cable on here ?
barefoot
Re: hand brake cable
Postby Fredjohn » Thu 07.03.2013, 20:20
barefoot wrote:Is there any instructions or guides for replacing the hand brake cable on here ?
Yes there are: try the "Manuals" section at the top of this page. Once in there, and you need to get an access code first (follow instructions) you can get a pdf file of the workshop manual and other goodies. Well worth it.
:-D :-D
Postby barefoot » Sat 09.03.2013, 15:01
I rang Paul in parts at Chris Neils and he has sent me a cable but when looking at the diagram on here it is showing 2 cables Chris Neils is shut now is it a case that I need 2 and are they both the same?
barefoot
Postby alan e » Sat 09.03.2013, 16:41
yes there are two cables one for each rear brake worth changing both at the same time done both on my car its a easy job.
2010 black evora
Austin 7 1932 box saloon
MG ZS EV
alan e
Postby Brit-Car-Nut » Sat 09.03.2013, 16:53
If your cable broke but not because of corrosion, maybe you should look closely at the sliders as that might explain your other rear brake questions.
There are TWO cables. They are the same, so if you only broke one, your order from Chris Neals will get you driving again.
