Airbag light/sound silencers on FED cars
Postby GoM100Go » Thu 02.05.2013, 08:28
I want to change out my steering wheel and was wondering what I can do to keep the airbag light from flashing and sounding when I find a new steering wheel i want to use. I just don't want blinking and sounds at random. Thanks.
-James
James
2009 Range Rover Sport HSE (Storono grey)
1991 Lotus Élan (Calypso Red)
GoM100Go
Re: Airbag light/sound silencers on FED cars
Postby steve matthews » Thu 02.05.2013, 12:38
I did not find that it sounded. The light bulb can be removed with the knee bolster removed.
Steve
steve matthews
Postby lotos » Wed 22.05.2013, 02:29
Doesn't the airbag still function if you put in another airbag wheel? Why would the idiot light stay on?
lotos
Postby Brit-Car-Nut » Wed 22.05.2013, 02:49
He is not putting an airbag wheel back on. There is probably a way to put a resistor between the two airbag connectors that fools the system into thinking the airbag is still there.
I will see what I can find.
Postby esprit888 » Fri 24.05.2013, 00:51
In order to trick and shut off the SIR light after replacing the ugly GM airbag wheel with a non-airbag wheel you simply need to install a 2-Ohm resistor across the airbag terminals, it will then cycle and go off as normal. This is a very common and proven method on the Esprit that has the identical wheel to the M100.
Colin
GoM100Go wrote:I want to change out my steering wheel and was wondering what I can do to keep the airbag light from flashing and sounding when I find a new steering wheel i want to use. I just don't want blinking and sounds at random. Thanks.
-James
esprit888
Postby GoM100Go » Sun 28.07.2013, 07:16
Don't know if anyone is following this but I found a solution to the light. This plugs into the ABS harness and cancels the light!
http://www.ebay.com/itm/MOMO-Steering-W ... 29&vxp=mtr
-James
James
GoM100Go
