Upgrade spark plug?
Upgrade spark plug?
Postby johnj » Thu 22.08.2019, 20:00
Is it worth upgrading spark plugs to platinum or iridium?
johnj
Re: Upgrade spark plug?
Postby GeoffSmith » Thu 02.01.2020, 20:08
Not sure, but I've just grabbed a set of Denso IK20TT iridiums from Opie Oils via Amazon for a very reasonable £36.30.
I was sucked in by the engineering and sales pitch!
Postby GeoffSmith » Thu 02.01.2020, 20:32
Amazon order cancelled. Let's try the even more reasonable FleaBay specials for £25.50.
Postby Saltire » Thu 02.01.2020, 21:58
GeoffSmith wrote:Amazon order cancelled. Let's try the even more reasonable FleaBay specials for £25.50.
Well spotted, Geoff - I’ve just ordered as well, along with a couple of NGK coil packs. Trying to get some Kingsborne plug leads, but their website’s a nightmare for non US buyers.
Postby GeoffSmith » Thu 02.01.2020, 22:14
They're about 10 miles away from Tiger Doug. Drop him a message if you are having a problem. Tell him I sent you. Better still, maybe best not to tell him I sent you. :lol:
Postby Saltire » Thu 02.01.2020, 23:55
OK, thanks, I’ll see if they reply to my overnight email.
Postby GeoffSmith » Wed 08.01.2020, 14:22
GeoffSmith wrote:I was sucked in by the engineering and sales pitch!
Sex on a stick!
Postby Saltire » Wed 08.01.2020, 16:30
Mine arrived yesterday. Red Kingsborne leads in the way. For future reference for anyone who’s considering the same leads, I Spoke to Kris Richter - very helpful chap.
Postby TrevorB » Wed 08.01.2020, 16:31
On ebay it gives you the option to check if it fits your vehicle. When I went through that process it told me it's not suitable
for the 1992 Elan Turbo ??
HiSpec front brakes
PNM rear brakes
Aluminium radiator
Closed Loop conversion
Kilimanjaro chip
Wannabe Princess
Postby Saltire » Wed 08.01.2020, 16:40
Hi Trevor
I’ve never found the eBay “Does it fir your vehicle?” tool to be anything other than patchy. All I can tell you is that the Kingsborne web site lists our car, they knew about it when I spoke to them, they were made to order, and BCN in Charlotte told me in passing that he has a set to fit to his car.
I’ll let you know what happens when they arrive!!
Postby Brit-Car-Nut » Wed 08.01.2020, 17:51
To be accurate, I told Jonathan I have a set of blue 7mm Kingsborne ignition cables. I still use BKR6E plugs (gapped correctly).
Look at the WikiLEC!
Postby Rambo » Wed 08.01.2020, 20:34
Sex on a stick!
Is that the right gap Geoff ? You're not boasting again are you :twisted:
Postby Saltire » Wed 08.01.2020, 20:41
Brit-Car-Nut wrote:To be accurate, I told Jonathan I have a set of blue 7mm Kingsborne ignition cables. I still use BKR6E plugs (gapped correctly).
Quite right, John. Apologies if I implied otherwise :oops:
Postby Simon_P » Thu 09.01.2020, 00:24
johnj wrote:Is it worth upgrading spark plugs to platinum or iridium?
In a word no!
Postby CallMeLegend » Mon 01.06.2020, 11:03
Under £10 for 4 plugs, seams a very decent price
https://www.ebay.co.uk/itm/4x-Lotus-Ela ... SwcUBYQcSq
CallMeLegend
Postby GeoffSmith » Mon 01.06.2020, 11:19
Postby japtojo » Mon 01.06.2020, 14:59
GeoffSmith wrote::agree:
Cheap yes but are they the correct ones?Denso catolog lists K20tt or iridium Ik20 or vk20
japtojo
Postby david924s » Mon 01.06.2020, 15:26
Changed mine at the weekend as the car was running rough and on/off cylinders so bought some NGK BKR6E (less than £10 for 4) and in case the leads were also at fault some cheap Cambiare leads (around £23) changed the plugs and the difference was like night and day, car runs perfectly no misfire and no issues so will keep the leads safe for the day I need them as the originals seems to be fine.
Old plugs were well past their sell by date and were badly fouled, probably due to short trips and limited usage for the last year.
david924s
Postby Brit-Car-Nut » Mon 01.06.2020, 15:32
What ever happened to using the correct original spark plug NGK BKR6E gapped to the proper specification?
(I was typing this as David was entering his post, thus the similar response.
Postby david924s » Mon 01.06.2020, 15:45
Brit-Car-Nut wrote:What ever happened to using the correct original spark plug NGK BKR6E gapped to the proper specification?
I would agree the prescribed NGK BKR6E plugs were cheap enough and my car is running a standard set up, boost etc so no need to go for anything more exotic, work fine in my car with the current set up gapped to recommended value and torqued to recommended setting. Each to their own but for me less than £10 was worth it to resolve the poor running and the leads I bought were only to test and confirm if I had a lead problem, but since the plugs resolved my issue I left well alone.
david924s
