by Brit-Car-Nut » Thu 11.06.2020, 17:38
Remember, the switch was used in other US and Canadian cars, so the switch will fit ALL of the versions.
You just need to figure out where the wires go and solder flag type female connectors, use a bit of heat-shrink and you have a cheap solution.
If someone wants to send me a harnessed version with a bad switch, I will be happy to make the mods and send it back.
I will also be happy to identify what each post on the switch does
by Saltire » Thu 11.06.2020, 19:29
dapinky wrote:I did however remember a simple fact from the 1990's - all self-respecting ram-raiding car thieves carried a 'Vauxhall black box' in their pocket {the actual switch bit we are all talking about} - they were all sufficiently interchangable to be able to hot-wire any car that they had snapped the ignition barrel off of with their 12" scaffold tube!
Bit old hat that, Dave; they’ve all upgraded now. I hear tell there are rolling code capture apps which work on Android phones. TWOC for Dummies.
- Location: Left foot in Wiltshire, right foot in Gloucestershire, heart in Scotland
by dapinky » Thu 11.06.2020, 20:41
True - but then I was specifically referring to the ram-raiders...... not the proper thieves.
Ram-raiders lost interest with the new generation of Cavaliers which had imobilisers (ie, nowt newer than an M reg) - they had a habit of getting caught when sitting in a car that wouldn't start
- LEC Administrator
by GeoffSmith » Thu 11.06.2020, 22:27
If you can sort it mechanically, there are 3 connections you need to make (see DIN 72552 for the switch connections which are probably marked on your defective switch):
Live feed to #30: Brown wire to ignition switch connector pin 2 comes out as red in the pigtail.
Switched ignition to #15: White wire to ignition switch connector pin 3 comes out as black in the pigtail.
Starter relay to #50: White/red wire to ignition switch connector pin 1 comes out as black/red in the pigtail.
There may be an extra red wire connected to the ignition switch connector pin 4 which does not appear to be used but the reference number on the switch and DIN 72552 should allow you to determine its function and whether to connect it or not.
https://en.wikipedia.org/wiki/DIN_72552http://www.dimebank.com/LucasColours.htmlhttp://wikilec.com/images/7/79/MJ25-02_ ... nition.gif
- Kitty Fiddler
