by ailwyn » Fri 19.09.2008, 15:53
GeoffSmith wrote:Now all we need to do is make sure that the
parallel universe is at the same potential.
However much you'd like to avoid it you are a mod and have the same ability as all other mods.
- Forum Member
by rushing » Sun 21.09.2008, 08:26
some people are genourous and like to to help someone who does not know much
. there is nothing wrong with a friend who is living very close by who has got the same car giving a helping hand to someone . if RIP wants hourly rate i think that is up to him to decide. Arent we all suppose to be helping each other out.... or we need to .........
rushing on Sun 21.09.2008, 16:16, edited 1 time in total.
rushing
by ESM » Sun 21.09.2008, 09:07
I had a look as well and I can't add very much. I also observed that the flags 43 bits seem to vary more than do in other cars and the changes in state cause big changes in both timing and fuelling.
The PROM is a very early one - it must be different to the later revisions in some ways but I can't say what those might be without seeing a PROM dump of it. I imagine a 9929 based ECU would work fine but its hard to say for sure without looking at the code. Was the replacement ECU a different PROM version or was the original 9998 memcal installed in it? If it was a different PROM id then the fact a code sets might indicate that the early version didn't detect the CAS error very well and was revised as a result. The symptoms do match a CAS issue quite well.
ESM
by Monty » Sun 21.09.2008, 11:27
ESM wrote:The symptoms do match a CAS issue quite well.
I did say a long time ago to change the HALL in the CAS a long time ago as it was only a 20 quid part
- Chunder King!
by dapinky » Sun 21.09.2008, 11:46
Monty wrote: as it was only a 20 quid part
Not that everyone pays £20 for them
- LEC Administrator
by GeoffSmith » Sun 21.09.2008, 14:33
dapinky wrote:Monty wrote: as it was only a 20 quid part
I though he had.......
back in June.
- Kitty Fiddler
by rushing » Sun 21.09.2008, 15:58
no i never came around to changing the CAS but changed MAP ,coils . thermo, cts, mat , --- hmm yes!! you were right MONTY i should have listened to you and tried this ohhh well worth changing the parts i guess. RiP did mention this too... my new ECU has got a lot of power-- its fantasic the old ECU did not detect any error nessages at all but i think it was playing up . i did the paper clip test yeasterday and it threw out error code 41 ---
i have bought a honeywell Hall sensor i will get this replaced . do i have to change the whole CAM or just changing the honeywell Hall sensor would do???
thanks to everyone especially RIP who has advised me and helped me out on the mechanics side . you guys have really given me sound advise... im useless when it comes to mechanics -- much appreciated...... i might have solved my long waiting problem
and what a thread
rushing on Mon 22.09.2008, 08:40, edited 1 time in total.
rushing
by rushing » Sun 21.09.2008, 16:10
i think the the old ecu is an old version . it is definantly chiped or something done to it coz when i got the car the stickers had been replaced and had a Barton motors seal on it so a garage must have done some work to it . yes ESM i never read fault codes hence thats why it did not read the CAS fault.
rushing on Tue 23.09.2008, 20:12, edited 1 time in total.
rushing
by Monty » Sun 21.09.2008, 16:45
Yep got the honeywell version from Hethel last weekend for £15 but it`s different to the one i fitted to Pinky 1 (many years ago
) ie there`s no instruction, no replacement connector and i`m sure the HALL had a plastic section that screwed in to the CAS
Jason, fingers crossed that solves your problems
- Chunder King!
by GeoffSmith » Sun 21.09.2008, 17:00
Just change the HES (Hall Effect Sensor) as this is quite a common failure and the usual reason for the CAS error. I thought you had changed and this was why you were suspecting the CAS to coil pack wiring. I would bet a Pound to a pinch of s**t that the HES/CAS has been at the root of many of your problems as an accurate CAS timing signal is fundamental to the engine's operation.
- Kitty Fiddler
by rushing » Sun 21.09.2008, 20:17
thanks Monty and Geoff i will just the hall sensor that should solve my problems . i had a year of it . its really when you cant drive the car. This ECU has made the trick . i really need to thank RIP for helping me out and to you lot. Yes the misfire and engine light comes up now and then. so its the cas . Geoff like you said ill just change the HALL sensensor . fingers crossed this should work. i will keep you all posted many thanks for the advise again ....
rushing
by rushing » Mon 22.09.2008, 08:45
Monty wrote:dapinky wrote:Monty wrote: as it was only a 20 quid part
yeah thanks Monty the new Honeywell sensor looks different hope it fits as the old one
rushing
by rushing » Fri 24.10.2008, 13:35
drove my car today after i got the cam belt done and HALL sensor done . the cambelt department is ok. car is
with the new belt and water pump. i guess . as you all are aware my hall sesor has been the major problems last copule of months and the mechanic put a new sensor in . so i tested the car after the job done . went 40 miles and back . the engine light did not come on nor did the bunny hopping symptom come on which the faulty HALL does . but when i got home just for curiosity did the paperclip test and code 41 popped up again .hmmmm very strange . does the ECU memory store this old code or does the fault still exist. the new HALL sesor wiring and pins are a bit different and the mechanic said the old hall housing is different from the upgraded lotus hall sensor . even the three black , green and red wires are thicker . but he said that he replaced the pins and replaced the hall as in the manual . no symptom but why is fault code showing . im getting paranoid now if the new hall i put is slightly faulty ..
might take the battery out and re set the ecu to see if the fault paper clip code show dissapears ..
rushing
by rip » Fri 24.10.2008, 15:04
rushing wrote:might take the battery out and re set the ecu to see if the fault paper clip code show dissapears ..
That should clear it...
Or you could do 50 journeys.
by Specky » Sat 25.10.2008, 10:17
I had a few minor issues with my new one...
The two solid rivets were loose in the head... a quick bit pinch with rivet sqeezers sorted that out...
and there's no mounting point on like on the S2's pipe... (ty-wrapped to the CAS)
I paid £19 and it takes 20 mins to fit... a well worth investment...
Here's a pick of the kitTTFN
by RonR » Mon 25.11.2024, 19:29
Holy Thread Resurrection!
For anyone doing a search on '9998', I've just examined a '9998' prom and here's what I found:
It looks like a standard '9929' prom with just 1 Byte difference in the code.
That byte is a Mask used in checks to see whether to raise diagnostic codes, the ones 'switched off' in comparison with a '9929' are:
Mass Air Pressure High
Cam Angle Sensor Error
Electronic Spark Timing Error
It would certainly explain why 'rushing's car didn't raise an error code when his CAS failed!
Perhaps the 9998 was a testing version which made it out into a few cars by mistake?
By the way, all the Boost parameters on this chip are the same as a standard 9929 Prom.
by Tuga2112 » Mon 02.12.2024, 11:12
is there a place anywegre in this forum were we have a description of each prom number and its known details ?
if there isnt one. im happy to create the post with all the relevant formatting . i just need a bit of guidance on where the details about each prom code are discussed
by RonR » Mon 02.12.2024, 11:50
Good idea Joao,
I've always referred to Alan's Mountain chips website for prom details, but his site's down at the moment, although a backup of the relevant page is still available
HERE on the Wayback machine.
It would be nice to have it at a central point on LEC in case Alan doesn't return to making chips and the Wayback machine folds.
I can add some details of the things I've stumbled across over the last few years.
