by andrewrenouf » Tue 12.02.2008, 13:47
Hi my normally reliable(ish) Elan broke down on me last week.
It was started from cold . I think the engine management light came on (can't remember) and it started misfiring and died after a total drive of 1 1/2 miles of driving. It would not restart.
I left on the side of the road and returned a few hours later. The car was cold again and started first time. I managed to drive it home and 25 metres before my drive it did the same! (I just got it into the drive).
I've been away for 2 weeks. Now it starts, runs for exactly 5-10 mins stalls and wont re-start.
Any ideas? It seems to die when it warms up.
Thanks - Andrew
P.S. If relevant, a mouse has lived in the car for a few weeks but has now been caught!! It might have chewed a cable!
andrewrenouf
by Specky » Tue 12.02.2008, 14:12
First thing is to check for a fault code..
Clicky Wiki
Doug normally has a therory, but I can't recal what it is...
by paza1 » Tue 12.02.2008, 14:15
Hi Andrew,
I would recommend a good visual check of your ignition leads (looking for chew damage and loose connections). Also, the paperclip test for any fault codes
http://wikilec.9600.org/index.php/Check_Engine_Light_Problems
Mark
Silver 1992 SE Turbo.
paza1
by andrewrenouf » Tue 12.02.2008, 14:24
Thanks for that, I've been away for a while and not only has the Website moved on but the You tube stuff on how to read the diagnostic light is fantastic!
Thanks again all who put the work in - Andrew
andrewrenouf
by Specky » Tue 12.02.2008, 14:59
andrewrenouf wrote:but the You tube stuff on how to read the diagnostic light is fantastic!
It's ok...
