by Enright » Thu 07.04.2005, 19:33
I've got to try to sort out my awful fuel economy, and plugs seems like a good place to start. The job needs to be done this weekend, which rules out overseas supply. But the choice at Halfords is a bit bewildering.<br><br>I could play it safe and stick with the standard NGKs/Boschs/Champions at around £11-£13, or I could push the boat out a bit and go for the Champion EON1s at £20, in the hope that they'll give a better bang for the buck.<br><br>What is the general consensus? Have you had any particularly good or bad experiences with any of the above (or any others for that matter)?<br><br>Ta!
Neil
- Modificator
by muley » Thu 07.04.2005, 19:47
The only plug I had fail was a Champion - mind you that was a LONG time ago, but I still tend to avoid them.
by Monty » Thu 07.04.2005, 20:35
Go for the 3 prong type hehehe :P<br><br>Think i fitted NGK`s. <br><br>If the gap is set right i wouldn`t think no matter which new plugs u use u won`t see much difference in fuel consumption ???
- Chunder King!
by John_W » Thu 07.04.2005, 22:15
[quote author=Enright13 link=board=ignition;num=1112898813;start=0#0 date=04/07/05 at 11:33:32]<br>What is the general consensus? [/quote]<br>New ones [smiley=thumb.gif]<br><br>John ;)<br><br>PS: then set your timing to 16 deg BTDC.
- Heid-bummer
by Ashaman » Sat 09.04.2005, 05:45
By: NGK<br><br>At: Any stupid platinum/gimmicky-expensive-type plug
Ashaman
by Darren » Sat 09.04.2005, 14:24
I'm sorry but there's only one thing you want a spark plug to do & that's spark.<br><br>If your getting a good enough spark to ignite the air/fuel mixture, then that's all you need it to do.<br><br>Why waste your money on a triple spark plug, when one spark is good enough ?<br><br>If you're questioning whether your spark is good enough, then check the gap, then start to look at the HT leads & the coil pack. Both coil pack & HT leads faults can lead to a weak spark.<br><br>For reference, I use bog standard NGK plugs as per the manual & my car turns in a half decent MPG, as well as flying nicely with one of Alan's chips installed.<br><br>Darren<br>~~~~
Open mouth, insert foot.
Darren
by M100 TWO » Sat 09.04.2005, 18:37
NGK for me they are hard to beat
M100 TWO
by Matt RI » Mon 11.04.2005, 20:58
[quote author=Darren link=board=ignition;num=1112898813;start=0#5 date=04/09/05 at 06:24:16]If you're questioning whether your spark is good enough, then check the gap, then start to look at the HT leads & the coil pack. Both coil pack & HT leads faults can lead to a weak spark.[/quote]<br><br><br>Speaking of- what is the correct gap for plugs? I looked in the manual and did not see it, so when I replaced my plugs and wires last month I just set them to the same gap as the ones that came out, not particularly the best method...
I like traffic lights. But only when they're green...
Matt RI
by Doug » Mon 11.04.2005, 21:02
[quote author=Matt link=board=ignition;num=1112898813;start=0#7 date=04/11/05 at 12:58:21]<br><br><br>Speaking of- what is the correct gap for plugs? I looked in the manual and did not see it, so when I replaced my plugs and wires last month I just set them to the same gap as the ones that came out, not particularly the best method...[/quote]<br>bad Matt -- bad! [smiley=1poke.gif]<br><br>There is 'supposed' to be a placard in the engine area that lists the gap. There was a definite thread on this last year = search for it.<br><br>Always gap your plugs; even if they are supposedly already set -- you will see why when you check them. The old gap will be wider than the starting gap, so yours probably need to be reset.<br><br>
<br>
- LEC Founder
by John_W » Mon 11.04.2005, 21:10
I set mine to 31 thou and the car goes quite well. ;D<br>John
- Heid-bummer
by Matt RI » Tue 12.04.2005, 20:35
I deserve it, Doug... I can hear my dad saying, "if you are gonna do a job, do it right!" taking three seconds to gap each plug out of the box does not do anything if you are setting the wrong distance...<br><br>Hence asking, as I was off by a bit. I had searched, and not turned up anything under "plug gap" except this thread. Sure it is on here somewhere, though... Asking is the lazy-man's approach! :-[<br><br>However, yes, .8mm or .0315" seems to do the trick.<br><br>Thanks Doug, John, and Dico, quick fix tonight!
Matt RI
by Andy_R » Fri 20.05.2005, 23:21
Matt<br><br>'Missing Under Increased Boost' is the thread you're after.
Andy_R
by lewtus » Wed 20.07.2005, 20:48
We actualy did a dyno run on an Esprit and saw 5 hp going to Denso Iridium plugs alone. I have them for years and they show now signs of wear and the car starts much better.
Lew
91' red Elan
91' #5 of 20 x180R....white!
lewtus
by M100 TWO » Wed 20.07.2005, 21:21
just fitted NGK iridium plugs BKR6EIX £8.03 each from
www.spark-plugs.co.uk the car seems more responsive but then one plug had discolouration orderd deliverd the next day good service
M100 TWO
Users browsing this forum: Chas54 and 5 guests
