A few Horses....More like a Grand National
Postby steve291274 » Thu 08.10.2009, 22:01
Having had the Elan for nearly a year now and being my second one I always felt this one was down on power. Anyway after GST did his magic freeing the wastegate it was better but even Gerald said its not producing the power delivery it should, and its running an Everest chip with a K@N. So after seeing a local company advertise with a rolling road I thought I'd give that a go. So I went to see them Wednesday morning, and the guy was very helpful telling me he'd never done an Elan before and that he used to own a Eclat and at only £35 I thought you can't go wrong. Within 15 mins the car was setup and ready for the first run.... :roll: 4th gear, flat out watching a very uneven power curve......125BHP....I thought, is that it........2nd run.........same again...........122BHP........O dear...........
So after a deccusion saying that he felt he could feel and blip during hard acceleration he suggested leads or plugs.
These are now on the way from SJSportscars. If these don't work I just want to know what route should I go down. What next :?:
steve291274
Re: A few Horses....More like a Grand National
Postby RichardK » Thu 08.10.2009, 22:09
Timing.....
RichardK
Postby GeoffSmith » Thu 08.10.2009, 22:16
My immediate first thought, but I would imagine it would have been Gerald's as well...
Postby steve291274 » Thu 08.10.2009, 22:19
Has been done by the man himself.... 16 degrees.... :!:
steve291274
Postby John_W » Thu 08.10.2009, 22:22
And if it's an S2, blocked cats.
Postby RichardK » Thu 08.10.2009, 22:24
Is it an S2 ? Strangled catalist/PCE?
125 is really Sh*te.....i mean seriously underpowered........compression test?
Then it's a something n the block issue....and even though I have replaced a turbo ( nearly) :banana: :banana: then I would head off to the prfessionalls
RichardK
Postby RichardK » Thu 08.10.2009, 22:27
You beat me by 2 mins John...Wot you stalking me or somithinigh>>>>!!!
RichardK
Postby John_W » Thu 08.10.2009, 22:48
RichardK wrote:You beat me by 2 mins John...Wot you stalking me or somithinigh>>>>!!!
:mrgreen: :-D
Two mins is a long time on here, Richard.
My :agree: was to your earlier post, and two people got in first while I was reading and typing.
If the timing's right, and it's not a strangulated cat, the other thing it could be is cam timing out by a tooth. Has the timing belt been done recently?
Postby Dave Eds » Thu 08.10.2009, 23:19
It's an SE not an S2. :wink:
Gerald also swapped the oversized back box for something nearer standard (the bigger one is in my garage!).
Steve - bring it round on Sunday and let's see what we can eliminate - I have spare leads etc etc etc. I'm guessing HGF may come into the equation.
BTW did Tom at Birchanger do the dyno testing?
Postby steve291274 » Fri 09.10.2009, 11:47
Cheers Dave. What time Sunday? I'm out Sunday afternoon after lunch, and yes mate it was Tom @ T.C.S. Hopefully should have the new leads and plugs from SJSportscars.
steve291274
Postby steve291274 » Mon 12.10.2009, 19:38
New leads............ Done. New plugs...............Done. Any better, slightly, on pick up only. Also checked the speed sensor as Gerald said, OK. :banghead:. The timing is ok although running a little rich. I am going to get Gerald to check to see if the cam is out by a notch although he said havin driven the car, it would have been running worse than it is. Would taking the Everest chip out for while make any difference :?:
steve291274
Postby Dave Eds » Mon 12.10.2009, 20:50
steve291274 wrote:New leads............ Done. New plugs...............Done. Any better, slightly, on pick up only. Also checked the speed sensor as Gerald said, OK. :banghead:. The timing is ok although running a little rich. I am going to get Gerald to check to see if the cam is out by a notch although he said havin driven the car, it would have been running worse than it is. Would taking the Everest chip out for while make any difference :?:
Steve - I missed your post on Friday and I've only just seen it now :oops: , so give me a call mate!
