Misfire end metalic sound
Postby Ted » Sun 12.01.2014, 17:39
Hi, I'm sorry for my bad english.
I have a problem since this afternoon.
I was driving fast in a curve, and when I accelerated as I went out the curve, the engine had misfire. I made 5kms to go home and it did'nt passed.
The oil level was at the low level (I add exactly 1 liter to have the upper level). After that, I restarted the engine and still have misfire, and a little metalic sound ("cliqueti" in french).
Does anyone have an idea? I've posted some elanscan in the correct section.
Ted
Re: Misfire end metalic sound
Postby lotusnut » Sun 12.01.2014, 20:33
I would do a compression check first.
lotusnut
Postby Brit-Car-Nut » Sun 12.01.2014, 21:00
Down 2 quarts, engine at high RPM and going around a strong curve, it is possible with the oil gravitating in the sump he ran out of oil long enough to damage the bearings.
Postby RayD » Sun 12.01.2014, 21:16
Ted, your English is fine.
Further to the other suggestions.
Hopefully you have only had slight oil starvation at the top end of the engine and the sound is coming from the valves. It may even rectify itself.
There is also a chance the shortage of oil and the misfire are unrelated.
Postby Rambo » Mon 13.01.2014, 00:16
Don't forget to try the paper clip test to see if any fault codes have been thrown up :idea:
Postby rip » Mon 13.01.2014, 13:50
I thought you were describing pinking.
Postby Ted » Sat 25.01.2014, 15:54
The engine was running on 2 cylinder. The coil of cylinders 2 and 3 was dead.
I replaced it, and changed the spark plug leads set, and it work fine :D
Ted
Postby HJ2 » Sat 25.01.2014, 16:27
Excellent news!
Postby tigerdog » Sat 25.01.2014, 17:25
:clap: :clap: :clap: :clap: :clap:
