by atikovi » Wed 16.11.2016, 17:45
Just noticed this while looking under the car.
Looks like it isn't even the right sensor. Shouldn't it be a 3 wire style? Could this be why when whenever I start the engine cold it immediately goes to 2500 rpm or more? Not good with no oil circulating yet. Wouldn't this have turned on a check engine light? And where would the connector on the other end be located?
atikovi
- Tinkerer
by dapinky » Wed 16.11.2016, 17:54
It's not the O2 sensor (which should be in the top of the downpipe, protruding through a hole in the heatshield)....
..... maybe an Exhaust Gas Temp sensor, which was only ever wired up in cars for the Japanese market (but this is purely a guess as I've not seen anything like it before).
- LEC Administrator
by Brit-Car-Nut » Wed 16.11.2016, 17:57
As I understand it, none of the 49 state FED cars have a CAT temp sensor (That is what you are looking at). Only Japanese versions do. I don't think FED California cars have that but I might be wrong.
High idle is usually caused by a vacuum leak or improper ignition timing.
by Elanlover » Wed 16.11.2016, 18:51
FED Cali cars have no such sensor either. Not on mine anyway.
by atikovi » Wed 16.11.2016, 19:00
Ok so it's not an O2 sensor. Don't see anything in the parts manual about it.
atikovi
- Tinkerer
by Elanlover » Wed 16.11.2016, 20:07
Do you have the Japanese parts manual? I'll have a look when I get a moment.
by Brit-Car-Nut » Wed 16.11.2016, 21:26
It is listed in the regular S@ parts guide but under the in-line area:
There is also a mention in the Service Manual V.6:
by atikovi » Wed 16.11.2016, 22:47
So did someone on the assembly line just drop in the wrong converter? Do I have a unicorn?
atikovi
- Tinkerer
by CalElan » Wed 16.11.2016, 23:42
Sorry, you don't have a unicorn, my CA version has the same none-connected wires. I noticed a couple of days after it last passed the smog test so didn't worry about it..
CalElan
by tedtaylor » Fri 18.11.2016, 15:19
Every time i see pictures of other owner's undercarriage with rusty, crusty, corroded, oily, dirty mess (please don't take offense), I'm so thankful for my clean and tidy one.
I have the same plug and tied up wire loom.... just hangs there not connected to anything.
TED
"Driving a Lotus is a triumph of bravery over intelligence." Stirling Moss
'73 Elan Sprint DHC
'05 Elise (solar yellow) my M100 replacement
TaylorMadeClassicCars on WWW and Facebook
tedtaylor
