by lotusrepair » Fri 20.11.2020, 19:03
I have been tracking my running problem to a bad spot in the throttle position sensor. The sensor on the car has soldered pins and the replacement has a plug connection. AS I have no history of what was done before, which is correct?
lotusrepair
by matts1972 » Sun 22.11.2020, 07:43
Hi,
Your TPS in the car sounds standard. The solder joints close to the sensor should be left alone.
There is a connector a few inches down the line where you can unplug and remove the TPS.
Best regards
Matthias
matts1972
by Simon_P » Sun 22.11.2020, 23:34
yes, soldered on. Although the only time I have looked the blue wire wasn't attached so I soldered it on which didn't make any difference.
You should be able to check TPS operation with elanscan - smooth operation of the throttle should give a smooth trace. Post a scan so we can offer suggestions.
by lotusrepair » Mon 23.11.2020, 00:19
I have had a consistent problem of engine cutout at 2900/3000 rpm. I also recently had the engine lose power in low rpm while driving and trigger the engine light. Run the rpm up and the engine light goes out and the car runs fine. In 15 miles it did it 4 times. This is why I am pointing to the sensor.
lotusrepair
by Simon_P » Mon 23.11.2020, 00:51
Did you get an error code for the CEL? TPS will trigger 21/22
Engine speed and throttle position are fairly independent. If you have a scan the throttle position integrity (or not) would be apparent.
by lotusrepair » Tue 24.11.2020, 22:37
I can't upload the elan scan files. The .ecu extension is not allowed.
Previously this year I had a error code of low TPS. I had 4 faults and all were the same.
After that I had a error code of high MAP. Faults were 1000 and all MAP
lotusrepair
by Fredjohn » Wed 25.11.2020, 09:42
lotusrepair wrote:I can't upload the elan scan files. The .ecu extension is not allowed
If you zip the .ecu file you can then attach it to your post and those on here knowledgeable enough will be able to analyse it.
by lotusrepair » Wed 25.11.2020, 22:14
Elanscans. two scans done months apart but very little driving this year.
lotusrepair
by Simon_P » Thu 26.11.2020, 00:48
2 scans with almost no data - 26s and 11s. To be of real use the scan needs to be from cold to fans on and whilst driving and reproducing the fault. 5 or 10 minutes of data.
From the 27 seconds of data ..
TPS looks ok it appears to be a stored fault - voltage is ok and % as good as matches - you need to put it through the full range of movement a few times.
MAP looks ok as a reading but combined with IAC indicates a vacuum leak or idle set wrong.
IAC is 10 it should be 20 at idle
Spark advance looks a bit retarded - but not enough data to understand conditions.
Check for vac leaks also check the throttle cable adjustment and stop position.
Check timing - see wiki
Set idle - see wiki
reset ECU
re-check
go for drive while scanning and try to reproduce fault then post the scan of the whole drive.
