TPS anyone ???
TPS anyone ???
Postby Oliver » Wed 06.09.2006, 18:11
Just wondering if anyone has a throttle position sensor or complete throttle body they could lend me for the postage. My ongoing running problem (2 years now) has not been resolved and the TPS is one of the last suspects. Lotus want £200 + vat for the sensor alone so i thought i`d put the word out to see if some kind soul had one they could lend me to try first. I`m in Maidstone, Kent & would return it quickly, or possibly buy it if you want to sell. Thanks for reading....
Oliver :m100:
Oliver
Postby paulwatkins » Thu 07.09.2006, 07:27
Hi Oliver,
I've got my engine stripped down at the moment fixing a 'piston problem'. I could remove the sensor, and would be happy to lend it to you on a short loan. My car is a 91 SE.
Let me know ok?
Regards, Paul
paulwatkins
Postby Oliver » Thu 07.09.2006, 22:13
Thanks for your kind offer Paul, piston problems eh, i won`t feel so sorry for myself now! Got my thermostat housing and distributor in bits at the moment, (yes it`s a non turbo), so i probably won`t need the TPS very soon and as it has to be calibrated when you remove/replace it i was really thinking of borrowing one from someone`s spares stash as opposed to butchering their own car. Thanks anyhow and good luck with the engine rebuild!
Oliver
Oliver
Postby chrisP » Tue 12.09.2006, 12:32
For the calibration its just a matter of measuring the voltage across a couple of the leads so you can do it with a multimeter. It doesn't take very long at all. didn't know if you were aware of it so thought i'd add it in
chrisP
Postby Oliver » Wed 13.09.2006, 22:27
Cheers Chris,
Iv`e got me voltmeter ready.
Oliver
Oliver
Postby ESM » Thu 14.09.2006, 07:13
You might want to try and get hold of an ElanScan interface if you've got long term problems (I'm not selling them now so I can say it). It works ok on NA.
ESM
Postby Oliver » Thu 14.09.2006, 20:32
I`ve known this would be of great benefit for ages! Got my old laptop and Elanscan program ready + engine management manual, just no bloody cable :cry:
Got a mate of mine making one for me but i dont like to rush him. I am fairly sure if i had elanscan working i`d solve it quickly.
Changed:
Plugs
HT leads
Cap + arm
pick up coil
ignition coil
ignitor
CTS (+just fitted another)
Fuel filter (loads) (yes it`s the right way round.)
Air filter (loads)
IAC valve
checked timing, cleaned earths, relays, connectors, EGR valve, pipes for air leaks, splits (cant find any)
Bitch to start, poor pick up till hot, and wont rev, symptoms gradually diminish with miles / heat, by the time i get to Goodwood its going like a rocket, hot starts ok, next morning won`t start again!!!!!
I think now it`s either:
TPS
Throttle body
weird air leak (unable to find)
clogged / knackered injectors
fuel pump
I`ll write a book about it one day.
Oliver
Oliver
Postby Oliver » Thu 14.09.2006, 20:35
Oh yes, just bought a temp guage sender from Lotus, it over reads big time. Now guage shows 3/4 all the time instead of 1/4. When i reported this as faulty they said it`s now discontinued anyway. So dont break yours!
Oliver
Postby GeoffSmith » Mon 20.11.2006, 01:15
Ratman is having troubles which I think may be TPS related. When he gives it welly, there appears to be a lack of power compared to a more gentle pressure on the accelerator. His ElanScan runs show that the TPS frequently starts to rise but then falls back and only occasionally hits 4V=100%.
As I'd got a bunch of ElanScan interfaces to check out, I thought I'd see how easy it is to check out the TPS. Procedure : Ignition on (but don't start the engine) set ElanScan logging then gradually press and release the throttle. I got the attached response - I think its fair to say my TPS is OK although I do only hit 97% fully depressed. I would expect a faulty TPS to give a noisy signal or not reach full output.
If anyone is after an interface, I currently have a few spare.
Geoff
Postby Enright » Mon 20.11.2006, 21:13
geoffsmith wrote:...I think its fair to say my TPS is OK although I do only hit 97% fully depressed.
Have you tried moving it round a bit or tightening the cable? A 3% power increase for free sounds like good value to me! :D
Postby Oliver » Thu 07.12.2006, 19:44
I am going to fiddle with my TPS again. When i have my ElanScan cable i should be able to adjust it properly. Anyone had a problem with the fuel pressure regulator ? I`m wondering if it has anything to do with my crap starting / running / over fuelling problem ?
Oliver
M100 N/A - No PAS
RenautSport Megane 275 Cup
MGF
Benelli 2C
Oliver
Postby Ekapol » Tue 12.12.2006, 20:20
I recently got my new TPS delivered after many moon of TPS blues. Still brand new never tried it yet. Turned out not the TPS itself in my case.
Please feel free to PM me if you want to borrow mine.
Ekapol
Postby Oliver » Tue 12.12.2006, 22:34
Thanks for your kind offer, I`ll hopefully have ElanScan up and working before the weekend so i may be able to confirm if mine is suspect.
I`ll keep you posted
Best regards
Oliver
M100 N/A - No PAS
MGF
Benelli 2C
Oliver
