by mascott » Fri 09.03.2007, 10:33
Hope some one can help me,after charging battery and refitting car wont start engine light on and no codes present however there is no priming sound wen ignition is turned on I presume this is the fuel pump priming.Where can I find relevant fuses or relay.Thanks in advance..matty
mascott
by stevieshag » Fri 09.03.2007, 10:42
if you removed the battery for charging check the inertia switch by the battery, its a small black button which activates if involved in a accident.
i know from experience that you can inadvertanly pull the switch up & experience the problems you have when removing the battery.
stevie
black lotus elan se (kermit)
Mitsibushi outlander
suzuki gsx 750 W (Gonzo)
stevieshag
by mascott » Fri 09.03.2007, 11:45
Tanks for the promt reply.I checked that and its in the down position.I have a bad feeling about this hope im wrong......
mascott
by Enright » Fri 09.03.2007, 11:49
Lift it and press it a few times. Mine sometimes does the same thing, and giving the contacts a bit of exercise can do the trick.
Also turn your ignition to the "prime" position a few times (waiting for a few seconds between each attempt) so that you get dashboard lights.
You only need to hear that familiar whine once and then it will start.
Neil
- Modificator
by mascott » Fri 09.03.2007, 12:08
I will give it a go when I get home thanks
mascott
by WillB » Fri 09.03.2007, 12:12
It could also be an immoboliser problem if you have an alarm fitted?
I've had that happen before........
WillB
by mascott » Fri 09.03.2007, 13:10
Thats a good piont it has an imobiliser that flashes....normally cant get the engine to turn unless I have used my key fob , at the moment it will let me turn the car over but only when I have used the fob so I presume the imobiliser side is working as it should.I am going to have a good methodical look later on...I was hoping there was a fuse that had blown due to trying to start the car with a low battery...I will make it to Donington i will i will..
mascott
by lotuska » Fri 09.03.2007, 14:28
If you've replaced the battery and you can't hear the fuel pipe start when you turn the ignition on you could have knocked the relay that controls the fuel pump.
It's located to the front of the battery, and it's something that I've had problems with previously.
Worth checking as it won't cost a thing.
lotuska
by mascott » Fri 09.03.2007, 16:15
thanks to everyone that has given me an idea of what to try I will give them a going over this week end "the suggestions that is not the people"
mascott
by mascott » Sat 10.03.2007, 09:08
Ok its running again thanks for all the advice.
I wish I could tell you what I did to fix it but as usual I just ploughed in and messed with the alarm the inrtia swithch the relay and some dodgy looking earths on the plenum and it started......Great site thanks again for your help see you at Donington hopefully Matty....
mascott
by Enright » Sat 10.03.2007, 09:40
Good, glad you're sorted.
If you're going on the Sat, have you seen the convoy thread
here?
We're trying to get 100 names on the list by the end of next week.
If you're on it, and are prepared to make a small donation, then you'll get a set of LEC windscreen stickers - and most tasteful they are too!
Neil
- Modificator
by mascott » Sat 10.03.2007, 10:15
ok will do thanks for the info...
mascott
