by tweetdriver63 » Tue 09.09.2008, 21:01
Basically, almost everything in the doors is hard to impossible to replace. The interior panels can be found at breakers, even here in the US, and the window glass is available. The window regulators are not. The motors can be rebuilt, and the sliders and rails are available new. There are write-ups in the Wiki about rebuilding/repairing the motors, and replacing the cables if needed. The motor also is the same as the Peugeot 405 rear window, I think, but the regulator isn't. You can swap the motor with some fiddly work. It's been done before. The escutcheons (the panel behind the interior door latch) aren't available, but since several members just replaced theirs with carbon-fibre ones, you may be able to find somebody here who'll give or sell you their originals if you're in need. I actually have a left side one I don't need. The door cards (the sort of oval-shaped leather-wrapped inserts) aren't available either, but unless the plastic behind it is badly broken, you can get them recovered pretty easily.
'91 Elan SE
'04 MB C230 Sport Coupe
'08 Mercury Mariner Hybrid
