The chances of losing a wire off the back is quite likely too..
I've taken a few pics, cos it may help:-
Gently put a screwdriver in this slot and release the whole light cluster...
This will allow you access to the wires for con checking as well, check the connectors as well
Use your screwdriver again from the rear of the cluster to remove the transparent cover
The red circles:- are held in place my small lugs
The green circles:- have legs that are part of the transparent perspex cover
a bit of teasing from the rear will remove this without any breaking...
The gree
