dapinky wrote:Hi David,
In the UK, the braking force is measured in kgf, not dekanewtons - but using a quick calculation I can tell you what mine passed the MOT with last time.....
FNS (left side) brake - 233kgf (approx 228 DaN)
FOS (right side) brake - 261kgf (approx 256 DaN)
ROS - 65kgf (approx 64 DaN)
RNS - 69kgf (approx 68 DaN)
NS handbrake - 108kgf (approx 106 DaN)
OS handbrake - 88kgf (approx 86 DaN)
This is quite an easy pass for the front, but quite low at the rear (as expected with the limiting valves), with the axle weight recorded at 784kg (front) and 484kg (rear) - the front has 63% efficiency, the rear has 27% - and an MOT requires 50% overall, which it achieves.
Fredjohn wrote:I know the handbrake cables need adjusting as it needs 6/7 clicks to come on.
CrtlAltSuppr wrote:Those 300 have been reached with the Wilwood?
rip wrote:You'll struggle to get close to that with the standard calipers.
dapinky wrote:rip wrote:You'll struggle to get close to that with the standard calipers.
I'd be quite surprised to see numbers much higher than mine with standard calipers, and probably a bit less
HJ2 wrote:Compared to every single other car I have owned (15 or so) they were rubbish IMHO.
Rusty Wishbone wrote:I am attempting to get as much out of the standard brakes on my Elan as possible by servicing them really well and fitting Ferodo pads at the front. We shall see how I get on in a few months.
