surferphil wrote:But how can it be done?
Oh, b****cks!
GeoffSmith wrote:surferphil wrote:But how can it be done?
Oh, b****cks!What colour do you want?
ailwyn wrote:I think (pretty sure) I picked it up from the VSS coming out of the instrument cluster, but I can check on the weekend.
Monty wrote:white/grey wire
GeoffSmith wrote:Monty wrote:white/grey wire
Nearly. White and Slate!
Probably the easiest thing is to pick up the three rev counter connections pass through an interface box and then take them off to a suitable panel mounting LED.
Is 1cm diameter too big?
It will take longer to develop but do you want it to change from green to yellow to red as you approach the redline?
surferphil wrote:Not for me off or on/red
surferphil wrote:If you are talking about the size of the LED how about ~5mm RED will show up nicely on my white dials.
surferphil wrote:How about a 5mm diffused LED, like the one on my Clifford alarm
with no bling just pushed through a hole, just big enough and glued to the dash on the back with a hot glue gun?
GeoffSmith wrote:It will take longer to develop but do you want it to change from green to yellow to red as you approach the redline?
Monty wrote:will this be adjustable or will it be set to 7k revs?
