ESM Chips - Information & Help
Postby nitroman » Sat 26.04.2008, 00:19
nitroman wrote:Hi Alan. The yellow M100 I just bought has an Everest v4.2 1499 chip. I'd like to upgrade to an Everest v4.5 1499. I read what to do at http://elanchips.appee.com/product.php?prodid=11 and it says "I will not supply this update unless you have purchased a kit with an earlier version from me in the past." Since I, personally, didn't buy it may I upgrade anyway? I don't mind sending in the v4.2 chip as proof, as I can just run off the factory-spec ECU in the interim.
Alan, Everest v4.5 1499 purchased via your site today.
nitroman
Postby jecuk » Tue 27.05.2008, 23:51
Just installed the V5 with switcher. Install instructions a piece of cake. Now I just need to drive it to see how it goes.
jecuk
Postby jecuk » Thu 29.05.2008, 00:23
Ran nicely but had overboost cut in when on map 7. Assume related to the larger exhaust on the car. Dropped to 4 and all OK. Will slowly push back up and see how I go.
jecuk
Postby John_W » Thu 29.05.2008, 08:18
jecuk,
At one time Andrew had both an Everest chip and a MBV on the car (he was investigating if the MBV could be used in conjunction with the chip to get over lag effects). This is not something to be advised if you don't know what you're doing (some would say, even if you do know).
Perhaps you had better check that the MBV has been removed or is set closed.
Postby jecuk » Thu 29.05.2008, 11:32
Thanks John. I will take a look. He never mentioned it but then again maybe he did and I forgot.
jecuk
Postby jecuk » Thu 29.05.2008, 18:02
So, I assume that is what the attached little beauty is. Will just need to take out the valve and then hope the hose has enough length to connect.
jecuk
Postby John_W » Thu 29.05.2008, 18:53
That's the one. A bit large and agricultural, but easy to spot.
Don't know if it's open or closed, but as a first attempt at curing boost creep, I'd remove it.
Postby jecuk » Thu 29.05.2008, 19:19
It is removed. Just soaking it in some WD40 to see whether it was open or closed.
Edited: On blowing through it, there is a leak from the bottom so looks like it is set to dump some pressure.
jecuk
Postby jecuk » Sat 31.05.2008, 16:09
After trying this out today, without the MBC, the car seems to run fine on map 7. Obviously it was just creating too much boost with the leak. As soon as I get an elanscan interface, it will be interesting to see the performance on screen.
jecuk
Postby GeoffSmith » Sat 31.05.2008, 16:44
If the MBC was inducing a leak, it is reducing the pressure on the wastegate actuation capsule which means the wastegate opens less - you therefore get more boost and/or the ECU cannot control boost creep and you get fuel cutout even at the higher level that the V5 settings allow. Effectively, the MBC is reducing the size of your wastegate and we know from experience that a big/free flowing exhaust is likely to require wastegate porting.
Of course, one advantage of the V5's are that the air fuel ratio is correctly and accurately mapped. under all conditions which is unlikely to be the case with the MBC.
Postby ESM » Sat 14.06.2008, 11:09
Good catch John.
The current chips don't have much much lag because they put a lot of opening on the BCFV instantly when the ECU enters boost control mode. The opening applied is around the amount I expect that will the target boost value on a standard car (the closed loop control then actively tunes the duty cycle to get exactly the right boost). So any MBC will almost certainly cause cut.
ESM
Postby Enright » Mon 16.06.2008, 21:58
XiPHiAS wrote:Just checking what chip I need and I am intrested in the switcher...
But... how do I know on what program I run? :oops:
Moved to here - no point in having a duplicate thread.
Postby XiPHiAS » Mon 16.06.2008, 23:16
OK, Sorry, but I spend one our to find my own question back :(
So if I put a realtime notification I will get notifications of un-related replys.
But, OK, u're the boss :wink:
XiPHiAS
Postby XiPHiAS » Tue 17.06.2008, 22:59
nobody? :cry:
XiPHiAS
Postby Nige » Wed 18.06.2008, 15:19
The beuty of the switcher chip is you can run whichever of the programmes you want. From .4 bar boost max (the normal wastegate opening pressure) to .95 bar with the Elysium programme.
Back in Blighty
Nige
Postby XiPHiAS » Wed 18.06.2008, 15:37
Nige wrote:The beuty of the switcher chip is you can run whichever of the programmes you want. From .4 bar boost max (the normal wastegate opening pressure) to .95 bar with te Elysium programme.
yes I know, but how do I know what programme I run ?
XiPHiAS
Postby F1 LOTUS » Wed 18.06.2008, 16:26
I believe there is a program number display?
F1 LOTUS
Postby XiPHiAS » Wed 18.06.2008, 17:38
O, cool...
that's a button that fits the Elan empty buttons?
XiPHiAS
Postby rip » Wed 18.06.2008, 22:18
XiPHiAS wrote:O, cool...
Yep. Fits nicely doesn't it?
I believe that pic is of Enright's Elan.
Some others have their switcher on the centre console, where the air con button would otherwise be.
Postby Enright » Wed 18.06.2008, 22:26
Good spot Rip.
When I first saw the picture I thought "cool - someone chose the same position as me. Oh and they've got the same fault code switch. And the same stereo. Hang on!"
XiPHiAS, which program you use entirely depends on your mood.
You should get a list of which program gives what boost setting. Then:
If you are leaving your car with a garage and you suspect that they may take it out for a spin, turn it down to minimum.
Going for a spirited blast or on a trackday? Turn it up to the max.
It's up to you.
Return to Upgrades
