A New Project Challenge for you - rev limit warning light
Postby surfboardfiller » Fri 18.04.2008, 21:14
I think I'll stick the LED somewhere in the dial face, like here.
surfboardfiller
Postby Monty » Fri 18.04.2008, 21:50
GeoffSmith wrote:I should have a couple ready for Phil and Nige at CC to try out. When is your next track day Jay?
errrrrrr good question. Easy answer is i don`t know :roll:
Was thinking of doing croft next month but i`m strapped for cash at the mo :cry:
But i can still test it on the country lanes :wink:
I was thinking of fitting the LED in similar place as Phil, just wonder if it would be better fitted to the Binical cover :?
Postby Nige » Sun 20.04.2008, 08:30
GeoffSmith wrote:Thinking of Ailwyn's HUD, I'm wondering if a narrow angle high intensity LED shining up from the dash cover would reflect sufficient back off the windscreen so that the warning is directly in your line of sight. Any thoughts A?
Thanks Geoff. Getting it into line of sight is key. so my inclination would be not to put it into the instrument cluster as this is not directly in line of sight when driving on the track.
Back in Blighty
Nige
Postby rip » Sun 20.04.2008, 23:49
Monty wrote:I was thinking of fitting the LED in similar place as Phil,
Not an ideal location.
Murph wrote:it's difficult to look at the cluster whilst on track.
You said so yourself :wink:
Monty wrote:just wonder if it would be better fitted to the Binical cover
That would be closer to your line of sight, so surely better for what you want it for?
Never done a trackday myself, but I know where you're coming from on this.
Postby surfboardfiller » Mon 21.04.2008, 10:42
Stick it where you like (I have a few suggestions for you) :smt097
surfboardfiller
Postby Monty » Mon 21.04.2008, 16:29
Where did you get that quote from :smt017
With an LED in the cluster it should catch your eye ie you don`t to look direct at it. when i`m on track some times the brake light comes on under heavy braking and you soon spot it out of the corner of you sight so think the LED will be ok. Binical does sound good but just worried if the LED might be a bit blinding as it`ll be directly in your sight :?
Postby GeoffSmith » Thu 22.05.2008, 22:26
Progress report: Having ironed out the bugs, we have some working disco lights operating from 2500-7500 RPM for Nige with a bright red rev limit light to go on top. The disco lights (but not the rev limit light) dim to a preset level when the sidelights are switched on.
Tried to solder the connector loom in permanently but couldn't find a convenient ignition supply - hope Paul W has some splice connectors spare.
Postby Monty » Thu 22.05.2008, 22:45
GeoffSmith wrote:Progress report: Having ironed out the bugs, we have some working disco lights operating from 2500-7500 RPM for Nige with a bright red rev limit light to go on top. The disco lights (but not the rev limit light) dim to a preset level when the sidelights are switched on.
Sounds great :smt023 any photo`s?
But don`t fancy having disco lights coming on as low as 2.5k revs :?
Postby surfboardfiller » Thu 22.05.2008, 22:52
Perfect timing! My dash is off and ready to build the new one (and Monty's CF bits while I'm at it). The Cat looks like sh1t right now! A wiring nightmare with 2 alarm systems awaits my gung-ho enthusiasm and ignorance :-D
surfboardfiller
Postby GeoffSmith » Thu 22.05.2008, 23:23
It's a prototype and hopefully we can get Nige on track to get some feedback. Lights can easily be left off if they're not needed, but at the moment there is a yellow LED at ~2500 (off boost), green LEDs at ~3000 up to ~6000, then yellow, orange and finally red at ~7000.
If you don't want the disco lights, then I leave that part of the circuit out and you'll have just the single LED when you hit ~7000RPM.
Postby Monty » Fri 23.05.2008, 11:38
GeoffSmith wrote:It's a prototype and hopefully we can get Nige on track to get some feedback. Lights can easily be left off if they're not needed, but at the moment there is a yellow LED at ~2500 (off boost), green LEDs at ~3000 up to ~6000, then yellow, orange and finally red at ~7000.
Good work as usual Mr smith :wink:
Will it be easy enough for you to change when the LEDs illuminate?
ie yellow at 6000, orange at 6500 and red at 7000 :-D
Will it still be possible to fit the unit in the instrument cluster?
Postby rip » Sun 25.05.2008, 01:09
post #11 of this thread :-D
Postby Monty » Sun 25.05.2008, 16:16
Took you awhile to reply to that one rippers :P
Geoff, any feedback from nige on the shift light?
Postby surfboardfiller » Sun 25.05.2008, 17:36
Monty wrote:Took you awhile to reply to that one rippers :P
I think he's still figuring out what went wrong, either that or he's thrown it out the window. :(
surfboardfiller
Postby Nige » Sun 25.05.2008, 17:38
We didn't manage to get the shift light fitted yesterday :( , so no feedback. I think Geoff was having a few problems with the unit and although we saw each other and had a chat last time I saw Geoff he was fixing a laptop. I/ve had an inspiration for a dashtop mounting as I think it could be made interchageable with my speed camera detector (an old Geodesy) as I've just bought 3 at a bargain price on ebay with an intent to canabalise them. I'll communicate this to Geoff and see if he thinks it will work.
Back in Blighty
Nige
Postby surfboardfiller » Mon 26.05.2008, 19:31
How big is the LED Geoff? I have the dial unit on my desk and want to drill a hole. :-D Does it matter or is it up to me how big I want my light? :D
surfboardfiller
Postby GeoffSmith » Mon 26.05.2008, 20:21
Sorry people, CC did my neck in and the weather's been bad so no chance to check why it didn't work on Saturday.
Phil, you can have it as big as you want - a quick look and I see that I can get them with 3, 4, 5, 6, 8, 10, 20, 50 and 120mm diameters and anything in between! I'd think 5mm is about right though.
Now, what colour would you like? Red, yellow, green, blue, amber, clear, ultra white, cyan, double hetero red (don't know if I can say that but what the hell), emerald green, orange, soft orange, red-orange, ultra super blue, warm white, ........... :-D
Postby surfboardfiller » Mon 26.05.2008, 20:29
GeoffSmith wrote:Phil, you can have it as big as you want - a quick look and I see that I can get them with 3, 4, 5, 6, 8, 10, 20, 50 and 120mm diameters and anything in between! I'd think 5mm is about right though.
5 mm in double hetero red :-D does double hetero red mean you like 2 women (or 2 men if you are a girl)? double hetero red = Definitely not g@y! :lol:
Censored!? WTF! :?
surfboardfiller
Postby Monty » Mon 26.05.2008, 23:14
Dear Mr Smith,
I might be doing Croft in July (depending on my money situation), will it be possible to buy one of your gadgets by then :wink: (I mean one that works :lol: )
Yours Sincerely
Postby GeoffSmith » Sat 31.05.2008, 07:39
You cheeky bugger McMurph. :twisted: I've been out of action with a virus this week so I haven't even looked at it yet. We'll see what we can do though.
Return to Upgrades
