ESM Chips - Information & Help
Re: ESM Chips - Information & Help
Postby grahamec » Wed 08.12.2004, 22:15
[quote author=ElanScanMan link=board=upgrades;num=1092641037;start=60#63 date=12/08/04 at 13:10:24]<br><br><br>I don't know, its the old 'how long is a piece of string' question. There have been a few people who have said that high boost power gains are only fully realised if the power enrichment is backed off a bit - this kit will give me the ability to find out for myself. I'll also be able to look at spark advance. It'll make testing a lot easier too since I'll be able to try as many setups as I can create without having to swap chips over.[/quote]<br><br>Good for you Alan, I'm sure those who do upgrades will benefit. :)
grahamec
Postby ESM » Tue 04.01.2005, 18:32
I've got the new adapters, chips and the PROM emulator!
ESM
Postby delta » Sun 27.02.2005, 01:24
Finally got the Elan Scan up running today. What a great programm. 8)<br>Have standard ex. and Eve. chip installed. :P<br><br>Was surpriced to learn that max. boost was 0,8 bars sharp. Should the Everest S2 chip not target 0.9 bar's.  ??? <br><br>Have a hard time with the Elan Scan.<br>Why is it that it shows power is between 20 - 80 Bhp (must be much higher) and it can ever read -300Bhp.(negative) ???<br><br>How do you show the torque curve. ???<br><br>Looking forward to do more tests tomorrow, and to do a dyno test soon.  8)<br><br>Can't you smooth out the power curve.  ???<br>I'm just confused, so advices appriciated.<br>Delta
delta
Postby John_W » Sun 27.02.2005, 09:41
[quote author=delta link=board=upgrades;num=1092641037;start=60#62 date=02/26/05 at 16:24:44]Finally got the Elan Scan up running today. What a great programm. 8)<br>Have standard ex. and Eve. chip installed. :P<br>Was surpriced to learn that max. boost was 0,8 bars sharp. Should the Everest S2 chip not target 0.9 bar's.  ??? <br>Have a hard time with the Elan Scan.<br>Why is it that it shows power is between 20 - 80 Bhp (must be much higher) and it can ever read -300Bhp.(negative) ???<br>How do you show the torque curve. ???<br>Looking forward to do more tests tomorrow, and to do a dyno test soon.  8)<br>Can't you smooth out the power curve.  ???<br>I'm just confused, so advices appriciated.<br>Delta[/quote]<br>Delta, <br>Yes ElanScan is a brilliant piece of work, and very useful to have (thanks ElanScanMan  [smiley=bowdown.gif]).<br><br>Have a look at the new "Dyno results" thread I started in this "Upgrades" section. It might make you want to get rid of the standard exhaust.<br><br>I've never believed the "power" calculation from ElanScan. On my car I can't get anything sensible from it. ElanScanMan will no doubt be along shortly to enlighten us. To measure and compare power (or torque) between different setups I use three methods: a) dyno results, b) ElanScan measurements of 0-60 (through the gears - prone to variability) and c) ElanScan measurements of 30-70 in 3rd (export the data points to Excel, plot speed vs time, and insert a straight-line regression line - gives good results but it's a pain to do).<br><br>If you do a dyno session, have ElanScan running and post results.<br><br>John  ;)
Postby charliex » Mon 28.02.2005, 04:27
i believe negative numbers are when braking, not sure about number though<br><br><br><br><br><br><br><br><br><br><br><br><br><br><br><br>
charliex
Postby ESM » Mon 28.02.2005, 08:44
Delta,<br><br>See http://www.lotuselancentral.com/cgi-bin ... 1099151472<br><br>You'd have to backcalculate the torque curve from the power info so it would be similarly noisy. The power values are 'at the wheels' but 80 is low.<br><br>When you get 0.8bar what is the 'wastegate duty cycle'? If its hitting 80% then you've got exhaust backpressure issues. If not I might have written a Kili by mistake... I'll send another chip if that looks likely.
ESM
Postby delta » Mon 28.02.2005, 16:26
Alan.<br>erhm..... not sure what it means, but boost go's strait up to 0.80 bar and then falls off to 0.75 as speed increase. Seems likely that the turbo cannot sustaine the high boost when more flow is demanded. Is that a backpressure problem. ???<br><br>Wastegate duty cycle stay at 0.80.<br> <br>Can send you the data in an E-mail, if this helps.<br>Delta
delta
Postby ESM » Mon 28.02.2005, 17:22
A BSV duty of 80% will give the maximum boost obtainable with your current system. To get 0.9 bar you'll have to either remove one of the cats or install a larger bore exhaust  :-/<br><br>Please send the data and I'll have a look.
ESM
Postby delta » Mon 28.02.2005, 19:42
Alan.<br>A couple of runs just send to your E-mail. Looking forward to hear what you mean about this.<br>Delta.
delta
Postby shumphr1 » Mon 18.04.2005, 03:59
Hi Alan,<br><br>I ordered a Kilimajaro through your website the other day and paid via paypal, but I guess my email couldn't have got through.  Can you confirm the order - paypal reference number 3V299470SM955172T?  I'm also after the connector to link up to the ECU, do you have any or still out of stock?<br><br>Many thanks,<br><br>Stuart Humphrey<br>Tel. 07813091305<br>email: watchoutwatchout@hotmail.com
shumphr1
Postby ESM » Mon 18.04.2005, 20:03
I have the order, your timing just isn't of the best because I've been on my travels recently - I'm in the US at the moment. I'm back home on Friday and I'll assemble all outstanding orders for chips over the weekend and post them on Monday. <br><br>Sorry about the delay  :-/
ESM
Postby Doug » Mon 18.04.2005, 20:38
what service . . . Alan has flown to Texas to help fix Doc Fizzix's dilemma   ;D
Postby Doc Fizzix » Mon 18.04.2005, 23:13
Yes Alan,<br><br>Come on over and I will treat you to some Texas BBQ!  Car is running great (but only with the chip AND the MBC)<br><br>I finally got a hold of an engine management guide so I can do some trouble shooting, I had to get it from Sports Car World in Waco, TX since the promised CD never showed up.  I plan to go through the manual page-by-page to make sure all sensors are working correctly and I will make sure that the engine is in perfect working condition, then I will remove the MBC and give things another go to see if anything changes.  Right now I am very happy with the performance even though I understand the chip should be used on its own and not with the MBC.  It would still be nice to know why the chip is not performing as designed with my system.   It might be helpful for others if we can find out what is going on with my system.
Doc Fizzix
Postby Doug » Tue 19.04.2005, 00:52
I think when Alan gets home he will send me some new code; I will then burn you one or 2 chips and beam then over to you.  If you are lucky then the new chip will cure the problem ???
Postby ESM » Wed 27.04.2005, 17:56
I've just burnt chips for all the outstanding orders, they should go into the post tomorrow.. If you're waiting, thanks for your patience.
ESM
Postby Avonvilla » Fri 17.06.2005, 12:06
Hi Alan, have you received my order for a Everest S2 chip on the 14th ?
Avonvilla
Postby ESM » Sun 19.06.2005, 12:12
Yeah,<br> sorry not to respond - working all the hours at the mo (at work now as it happens  :()<br><br>It'll go out in the week.<br><br>
ESM
Postby Avonvilla » Sun 19.06.2005, 15:25
Ok no prob.
Avonvilla
Postby ESM » Mon 11.07.2005, 23:50
New stock still not arrived, completely out, even sold the ones in my cars :(
ESM
Postby ESM » Fri 15.07.2005, 11:54
Just got a load of adapters and chips! I'm back in business.
The import charges are bit steep £10 import duty, £53 VAT and a £14 pound 'clearance fee' from the carrier :roll:
ESM
Return to Upgrades
