Helpful to use lift when installing AB Motorsport gearcable?
Postby lotos » Wed 31.03.2010, 21:14
My buddy has access to a lift at his work and has offered to help me install the AB Motorsport gearcables and the short shift kit.
Is it helpful to use a lift? Or is it unnecessary? The shop is 40 miles further down the road.
lotos
Re: Helpful to use lift when installing AB Motorsport gearcable?
Postby steve matthews » Wed 31.03.2010, 21:52
No, just completed this very assembly. You will have great joy. :-D
Take your time, allow ample time.
1. center shifter
2. Cable ends at trans. will be tight. Lube will not help. :shock:
Enlarge opening with small rat tail file. But do not over enlarge. :roll:
Steve -w-new lady :m100:
steve matthews
Postby HJ2 » Wed 31.03.2010, 23:00
Replacing the normal cables takes 45 mins, no lift involved, but can be handy to fish for cables or just to allow for a comfortable working height
Definitely not necessary :-D
Good luck!
Postby lotos » Thu 01.04.2010, 00:03
Thanks for the info! Is this the best guide for installation? http://www.abmotosport.com/Elan_gearcable_fitment.htm
lotos
Postby steve matthews » Thu 01.04.2010, 01:14
That's it. Don't forget the rat tail. ;-)
Steve
steve matthews
Postby rip » Thu 01.04.2010, 17:55
steve matthews wrote:Enlarge opening with small rat tail file. But do not over enlarge. :roll:
:shock:
I had no problems at all with that bit. Could Fed & UK Elans have differences in that area?
Edit: Must have been drinking when I posted that...or somehow misunderstood it. :oops:
Postby ecb056 » Thu 21.06.2012, 11:40
Does anybody have a PDF copy of the AB cable installation instructions that were posted at http://www.abmotosport.com/Elan_gearcable_fitment.htm?
This domain has expired.
I have AB cables on the way from DB.
ecb056
Return to Upgrades
