surfboardfiller wrote:I have just fitted a Manual Boost Controller and have some questions for the Guru.
Will the standard ECU automatically keep up with higher boost pressure or will I get incompatibility issues?
Does the MBC do the same job as an Everest chip?
Will bad things happen if I take the car for a run?
Thanks,
ESM wrote:Post here any driving impressions, dyno data, links to ElanScan logs etc. relating to the mountain chips.
saska wrote:Phil, I'm not a guru but I'll tell you what I think and explain my reasoning. May help until ESM shows up.
The ECU reads the amount of boost from the MAP sensor off the intake plenum. This figure is essentially the current MAP reading minus the barometric pressure read at ignition switch on.
The ECU adjusts fuelling via injectors (pulse width). According to the engine management manual the ECU cuts fuel; a) when the MAP sensor registers overboost, b) when the engine is switched off (to prevent dieselling) and c) when no CAS signal is received (engine not turning). The ECU cuts fuel in the overboost situation via the injectors which it still has control of so it should still cut fuel at 0.95 Bar with an Everest.
Regarding the engine protection (richen mixture at high boost/high revs) this should still work for similar reasons. The ECU can still detect high revs and high boost (via the MAP) and still control the amount of fuel via the injector pulse width.
With the normal setup the boost contol is done by causing a controlled leak to stop the wastegate opening too early -- the ECU doesn't know if this works or not. The only way it knows about boost is via the MAP hence why stuck wastegates have had people eating steering wheel at fuel cut.
For similar reasons I believe the ESC (electronic spark control) should also work as normal (well Everest normal).
HTH
I was going to post something similar (honest!)
surfboardfiller wrote:The MBC is quicker at calculating the waste gate/boost control. There will be less compensation required by the fuelling with less fluctuation of pressure and loss of boost control (stalling, turbulent flow etc) as the MBC will stay on top of the boost control. That's one of the main reasons for using it.
surfboardfiller wrote:Well I didn't come on this thread to discuss the * Boost controller, I came here to see if I needed a mountain chip and if a chip would help or work against my new system, which I think is on topic.
But as usual I find myself defending my comments and being taken off topic by people who don't intend to help me at all, just pick at little things I happen to mention, whilst I'm trying to get a simple answer from someone who knows what I'm talking about.
i wish to state the following......"bogsRus" was a vain effort at humour....... Bogs Are Us....... Plumbers merchants.......surfboardfiller wrote:Server not found
.... I give up! .. you were asking a question about MBCs and the standard ECU so this is not as Alan requested, i.e. "Post here any driving impressions, dyno data, links to ElanScan logs etc. relating to the mountain chips." which is why it has been moved.I have just fitted a Manual Boost Controller and have some questions for the Guru.
Alan wanted this topic to be specifically about Mountain performance (in the same way that you have previously requested topics you started remain on topic) and he didn't want it cluttered with other discussions. If you want a chip with higher level of fuel cutoff, you can go to his site and order one. Oh and another thing: Good job I'm not a moderator then....surfboardfiller wrote:Do what you want with my posts, it seems the moderators on this forum are more concerned with their own pedantic urges, than keeping the forum free of the junk posts or helping as usual, which is why I regularly get put of having anything to do with this forum.
surfboardfiller wrote:Since Tony has answered the initial question the follow up is: how can an ESM chip help improve the performance of my car considering my new setup? Which I guess is one for The ESM
