What chip is in my car?
Postby Hoppo » Sat 27.04.2019, 17:15
While looking at a few bits the other day I noticed that someone has written "chip" on the ECU case.
Is there any way to tell what's in there?
Hoppo
Re: What chip is in my car?
Postby dapinky » Sat 27.04.2019, 17:20
If you have elanscan, you can plug it in and it will tell you......
.... failing that, you will need to remove the ecu from it's bracket (2 small bolts and the wiring plugs). There is a sticker that is fitted at the factory to prevent 'tampering' - if this is still intact, then the unit has never been opened, so a chip is unlikely. However, if it has been peeled back or cut, then you can easily open the case. If the chip is a 'mountain' chip, then it will be written on it what it is, if it's a 'superchips' one, it will be printed on the chip.
Postby Hoppo » Sat 27.04.2019, 17:31
The tamper proof label has been off. Any chance of anyone has a pic of what I'm looking at?
Hoppo
Postby GeoffSmith » Sat 27.04.2019, 17:53
Take a look here.
Postby John_W » Sat 27.04.2019, 17:55
Lots of info on the Elanchips website. Follow the link at the top of the page.
Specifically, you’ll find photos here:
https://elanchips.co.uk/index.php?optio ... 7&Itemid=8
Return to Upgrades
