How much extra power from an everest chip
Postby johnj » Wed 29.05.2019, 20:29
I am buying a chipped Elan but the insurance company wants to know how much extra power the car puts out. It is a S2 and has a 2.5 inch exhaust an upgraded air filter and an Everest chip. I assume it started at 155 bhp but where did it end? Does any one know how much extra power the chip puts out?
johnj
Re: How much extra power from an everest chip
Postby alan e » Wed 29.05.2019, 20:34
Which chip is it ?
2010 black evora
Austin 7 1932 box saloon
MG ZS EV
alan e
Postby Rambo » Wed 29.05.2019, 20:54
alan e wrote:Which chip is it ?
Here's a clue Alan :lol:
johnj wrote:It is a S2 and has a 2.5 inch exhaust an upgraded air filter and an Everest chip
Postby johnj » Wed 29.05.2019, 21:09
I think the insurance company wants to know how much the percentage increase in boost is rather than expected bhp as I originally thought.
johnj
Postby ab2cv » Wed 29.05.2019, 21:17
35bhp is a 21% increase over 165bhp, if my arithmetic is correct (35/165)*100
Yellow Esprit GT3
ab2cv
Postby alan e » Wed 29.05.2019, 21:26
My mistake smart ass :banghead: about 45 bhp then. total bhp from a Everest chip is about 200.
2010 black evora
MG ZS EV
alan e
Postby John_W » Wed 29.05.2019, 21:33
If you follow the link to the Elanchips website at the top of the page, on the right just under the LEC banner, the “about chips” section states:
Stock Turbo Elan
Maximum programmed boost 0.65bar
Fuel cut limit 0.92bar
Boost pickup rate quite slow (boost lags behind target value under heavy throttle)
Nominal power 165bhp (flywheel)
Everest
Maximum programmed boost 0.9bar
Fuel cut limit 0.98bar
Boost pickup rate enhanced
Dyno power 200bhp (flywheel estimated)
If the extra power is a problem, don’t let it put you off the car if it’s a good one otherwise. The chip can easily be changed back to standard: again see the Elanchips site fitting instructions.
Postby alan e » Wed 29.05.2019, 21:38
John_W wrote:If you follow the link to the Elanchips website at the top of the page, on the right just under the LEC banner, the “about chips” section states:
Stock Turbo Elan
Everest
That's for a SE he's got a S2 which i my be wrong is 155bhp.
2010 black evora
MG ZS EV
alan e
Postby johnj » Wed 29.05.2019, 21:47
I thinks an s2 has 155 so if all the mods give 200 bhp that is 45/155 x 100 = 29 %. More that 25% boost and I have not found an insurance company to cover me
johnj
Postby alan e » Wed 29.05.2019, 21:55
I am with Admiral insurance my car's got a Everest chip and all the mods you have + PNM brakes which they know all about and with a agreed value.
2010 black evora
MG ZS EV
alan e
Postby alan e » Wed 29.05.2019, 22:06
It's also in the heading which we both missed :banghead: :banghead: :banghead: :bonk: :bonk: :bonk:
2010 black evora
MG ZS EV
alan e
Postby Rambo » Wed 29.05.2019, 22:10
johnj wrote:I thinks an s2 has 155 so if all the mods give 200 bhp that is 45/155 x 100 = 29 %. More that 25% boost and I have not found an insurance company to cover me
Everest chip only adds 35 bhp max as previously mentioned viewtopic.php?f=44&t=27430 Assuming your S2 belts out only 155 bhp when finely tuned that makes an added increase of 22.58 %
I've never had any problems with any insurance company when declaring an Everest chip in over 15 years of ownership
PS if you have an aftermarket 2.5" ss exhaust you may also have enhanced performance. Typically 8 bhp
Postby Rambo » Wed 29.05.2019, 22:17
That was the first thing I saw before I read the posting :?
Postby clemo » Wed 29.05.2019, 22:23
Toasted the other double thread . Rambo has answered the same on here for you .
Cheers all
clemo
Postby Rambo » Wed 29.05.2019, 22:27
Of course the definitive answer can only come from a rolling road test. Measure the performance at the flywheel in the stock set up. Then repeat the test with the Everest chip in situ and do the maths to get the true and accurate result
Postby Fredjohn » Wed 29.05.2019, 22:41
I agree with the % requirement from the insurance company. Once mine were told the increase was 21% (SE) they did not alter the premium at all. So 22% should fall into the same category. If they do put up the premium, then go to another company. I have mine on a classic policy with Footman James (Other companies are available).
Postby Simon_P » Wed 29.05.2019, 23:09
Rambo wrote:Of course the definitive answer can only come from a rolling road test. Measure the performance at the flywheel in the stock set up. Then repeat the test with the Everest chip in situ and do the maths to get the true and accurate result
Like this
https://elanchips.co.uk/index.php?optio ... 3&Itemid=4
Interesting that in each case a large bore exhaust gives a lower result.
Postby Rambo » Thu 30.05.2019, 05:37
"Dyno data is intrinsically pretty variable"
That's interesting. And the repeat dyno testing does look a bit noisy :?
Looks like for most of the dynamic range that a larger bore exhaust gives less bhp and only a marginal increase at 6000 rpm (Everest only)
Need to discuss this further on FB :twisted: :twisted: :twisted:
Postby John_W » Thu 30.05.2019, 14:55
I wouldn’t worry too much about the accuracy of that particular graph, or read too much into it or draw too many conclusions from it. It was put together, as it says, from various cars on various dynos and therefore is a bit of a hodge-podge. The chip development thread (now gone) discussed it.
The other graphs (like the “most boost and power without knock” which decided on map 8 for the updated Everest) were taken from tests under more controlled conditions and so are more reliable (but note that the “repeatability” point taken on map 8 shows that even that data has variability; however the trend is clear).
Trying to stray back to the OP’s concerns, the Everest gives + or - 20% increase in power by increasing the boost (in an engine-safe manner). Just because you have an S2 it won’t give more than 20%. You won’t be able to stick an Everest chip into a car that has 80bhp and end up with 200bhp.
Postby Simon_P » Thu 30.05.2019, 15:44
In the absence of exact data it gives a good picture of the likely increase. Sufficient at least to say more than 20% increase. The difference between SE and S2 is not statistically significant given the magnitude of the increase.
Return to Upgrades
