BBR Kit what does it do exactly ?
Postby lotuselan4455 » Fri 01.06.2007, 19:25
Can anyone tell me how a BBR kit works ? and are these worth fitting ? Can they be used in conjunction with a MBC ?
lotuselan4455
Postby John_W » Fri 01.06.2007, 20:01
lotuselan4455,
I don't have a BBR kit, however I've seen bits of them. As far as I am aware it comprises two components: an electronic box of tricks and an orifice (several different sizes are provided) which is inserted into the 3mm pipe between the turbo wastegate and the ?BSV.
Although you'd expect the electronics to be the part which gives the extra boost, it's not. All the electronics do is negate the ECU's automatic fuel cut-out defence. The bit which actually gets you the extra power is the little metal orifice. In other words the BBR kit is a fixed MBC with a FCD.
Are these worth fitting ? In my opinion, no. Better to buy a Mountain chip which retains all the ECU's defences and is a much more elegant solution to getting extra power from the Elan. It is also much, much cheaper than a BBR kit.
Can they be used in conjunction with a MBC ? As far as I am aware, the BBR kit is an MBC, albeit a non-adjustable one.
Postby Doug » Fri 01.06.2007, 20:31
:goodposting:
John, you're supposed to post the link the Alan's site -- isn't it www.ElanChips.com ??
Postby John_W » Fri 01.06.2007, 21:50
Doug wrote:John, you're supposed to post the link the Alan's site --
:oops:
Doug wrote:- isn't it www.ElanChips.com ??
:smt023
PS: I recommend the Everest. :-D :burnout:
Postby GeoffSmith » Fri 01.06.2007, 22:49
:smt045 Fit the best. Fit Everest.
Postby Doug » Fri 01.06.2007, 23:28
If you send an undamaged kit back within 30 days, for any reason, you'll get a full refund minus postage & packing costs. All UK orders are sent recorded delivery.
could it possibly be a better deal?
will be safer and more perfect an upgrade than any MBC or BBR ever wished to be.
Postby GeoffSmith » Sat 02.06.2007, 07:20
geoffsmith wrote::smt045 Fit the best. Fit Everest.
For Doug's benefit, oldies nostalgia and mild amusement ....... Ted Moult.
Return to Upgrades
