by Elanlover » Fri 07.12.2007, 21:40
For those that are considering going to 17" rims (or already have done so) I thought the attached chart might be of interest. It shows what size tires have what impact on the speedo, etc. when installed on 17" wheels. I was quite surprised to see what wheel/tire combo yielded the closest to OEM results.
by Elanlover » Mon 10.12.2007, 17:40
And, if you start with the belief that the Elan was designed first with a 15" wheel (with the 16" added for the Fed market initially) then you'd want to start with the stock 15" dimensions first which yield even different results.
Return to Wheels and Tyres
