Which new tyre for the front.
Postby schurch » Tue 14.02.2006, 12:23
I discovered that I had a flat front left tyre thismorning. Very annoying.
Assuming that I have to replace the tyre, on both front wheels I imagine, what is the current recommendation?
Options appear to be...
1) Michelin Pilot EXALTO PE2
2) TOYO PROXES R888 - (sounds like a bad idea regarding wet driving)
3) Yokohama A022
I can't find any websites offering the Goodyear Eagle F1s (which I would prefer since they are on the front already), the Dunlop SP sport 9000s (which I'm running on the back) or the Toyo T1-S (which seems to have pretty decent reviews here). If anyone knows better and can point me to a place to get these that'd be great! Otherwise, any opinions on which of the above would be best?
schurch
Postby Enright » Tue 14.02.2006, 13:21
How much tread did you have left, and what caused it?
Kwik Fit plugged one of mine from the inside when I had about 5mm left and got a screw through the middle (ooer missus). It's given me absolutely NO trouble since - in fact I can't even remember which tyre it was!
Postby schurch » Tue 14.02.2006, 13:39
I have about 4mm tread left. I'm gonna try kwikfit tonight to see if they can repair it like that, but if not I should be prepared! ;)
Glad to hear you've had no trouble after the repair... even under hard driving I assume. That'd be the best solution then.
schurch
Postby theelanman » Tue 14.02.2006, 14:54
wots the tyre youve got a hole in....
I got a garage full of part worns and I'm up you neck of the woods on thurday!!!!!......
I'm sure we could come to some arrangement
the pilot is brand new....
pair of pirellis
full set of maragonis
and i cant remember what the other one is
if it helps.....?????
Postby schurch » Tue 14.02.2006, 15:03
Oooohhh, lucky me. I found a pair of brand-spanking-new F1s on Ebay for 130 quid. Sorted.
Thanks for the offer elanman - I'd bought the F1s before I saw your post - sorry. Feel free to give me a shout when your up here if you've got time for a beer and nothing to do.
schurch
Postby Andy_R » Fri 17.02.2006, 16:48
Just a note on tyre repare - it's only the flat centre section of the tread pattern that's repareable, anything outside of that, or on the side wall and the tyre has had it.
I had a new set of Toyos and had a thorn go through the side wall of one after less than 500 miles, and had to replace it - my fault for driving into the hedge I supose.
Andy_R
Postby Sy V » Fri 17.02.2006, 16:53
The R888s are a very bad idea. Yes, they're road legal, but essentially they're a track tyre.
LEC Godfather
Postby Andy_R » Fri 17.02.2006, 20:42
...quite right
(have I got to 100 posts yet?)
Andy_R
Postby dans » Fri 17.02.2006, 21:26
there are specialists who will repair punctures on the wall in some circumstances, if you have one local its only a few quid, otherwise some garages send them away to be done, costs a bit more though.
I know some don't recommend this ........
dans
Postby Ultimatt » Fri 24.02.2006, 14:39
Don't want to depress you, presuming you still have the stock wheels on your Elan, but I just got 4 brand new Goodyear Eagle F1s off mytyres.co.uk for my brother. He's getting them for a Honda Civic, but the spec was 195 50 15s for £129 all in, including delivery. can't see the 205s being much more.
Matt
Ultimatt
Postby Costas » Fri 24.02.2006, 23:32
Sy V wrote:The R888s are a very bad idea. Yes, they're road legal, but essentially they're a track tyre.
So wisely spoken, couldnt agree more!
Costas
Power 362hp (437hp NOS)
Costas
Postby theelanman » Sat 25.02.2006, 02:54
I paid £165 for 4 yokohamas ac01
205 45 16
fitted balanced (stick on weight on the inside)
Postby schurch » Mon 27.02.2006, 17:55
Ultimatt wrote:Don't want to depress you, presuming you still have the stock wheels on your Elan, but I just got 4 brand new Goodyear Eagle F1s off mytyres.co.uk for my brother. He's getting them for a Honda Civic, but the spec was 195 50 15s for £129 all in, including delivery. can't see the 205s being much more.
Matt
Considering that Goodyear don't make the F1 205s anymore (and havn't for quite a while) I wouldn't be at all surprised if they were much more! ;)
I check on mytyres.co.uk - thats where I got my dunlop sport 9ks - but they didn't have any :(
schurch
Return to Wheels and Tyres
