Speedlines on an Elan, Your thoughts
Re: Speedlines on an Elan, Your thoughts
Postby m100sandra » Thu 25.04.2013, 17:16
:D Car MAD family :D
m100sandra
Postby chris.t » Thu 25.04.2013, 18:02
So it seems :-)
Postby Rambo » Thu 25.04.2013, 18:08
chris.t wrote:I remember following monty on the way to Bedford autodrome, it was like a firework display :)
That's normal :lol: :lol:
It does seem to be sitting rather high Sandra. Is it still on the original springs and dampers ? I'm sure it will be on that low mileage but I have seen a few others that have changed springs and inserted the wrong (American type) ones. Mainly SE's though I must admit
PS Just a thought but is your front black number plate road legal ? I thought only cars of a certain age could have black with silver letters and all others had to have the white background with black letters.
Postby m100sandra » Thu 25.04.2013, 19:22
99% sure they will be standard springs.
If you look closely you will see some velcro on the black plates. just for show(s) white and yellow for the road, think its pre 73 for black plates :?:
m100sandra
Postby whippit » Fri 26.04.2013, 00:13
mine had 20k on the clock when i picked it up and its sat about an inch lower than yours on standard 20 year old springs,
i bought some standard springs from sj's last year and fitted them, the car looked like a 4+4 so replaced them with the originals,
mines still on standard dampers and springs all round as i dont use it in anger, still felt stable on the Donington afternoon drive chasing GUK around the roundabouts ,
whippit
Postby chris.t » Fri 26.04.2013, 09:54
Whippet, they'll be the federal springs. I fitted some and turned my elan into a monster truck. Like you I changed then back to the old springs.
Postby Brit-Car-Nut » Fri 26.04.2013, 11:16
Chris.t and whippit: What did you do with the Fed Springs? I might be interested in a spare set or two as I will eventually have both cars repaired. Thanks.
Postby chris.t » Fri 26.04.2013, 11:32
I can dig them out if you need them.
Postby Brit-Car-Nut » Fri 26.04.2013, 13:24
That would be very generous. Please give me a price and let me know if you have all 4 springs or just fronts or rears. I am still collecting parts near Doncaster, Notts, so would want to get them there but I can arrange courrier and send you labels in PDF format.
Postby chris.t » Fri 26.04.2013, 13:56
I'll get back to you, I have all 4.
Postby Brit-Car-Nut » Fri 26.04.2013, 14:00
Thanks.
Sorry for hijacking the topic.
Postby m100sandra » Sun 12.05.2013, 11:38
Just got the Elan back from Cornering Force, what a diference :) Full GEO set-up including corner weight etc http://www.corneringforce.com/setupanalysis.html Ill post some pics in the post your wheels thread now that its lowered :)
m100sandra
Postby Peter D » Mon 25.11.2013, 22:15
How did you solve the cone issue for the bolts ?
I was told (by Chris Jordan at Speedlinecorse.co.uk) the Speedline SLS676 have 40° cone, and only Bordanova in France can deliver nuts.
The nuts are M12x1.25 thoug, so you would need to use conversion studs from M12x1.5 to M12x1.25.
Looking at your pictures, you managed it with bolts..., where did you find them ?
And what did U use as centre caps ?
Speed has never killed anyone, suddenly becoming stationary… that’s what gets you.
Peter D
Postby m100sandra » Fri 29.11.2013, 21:35
Sorry i missed this post :( i used conversion studs......and the correct deg taper wheel nuts which they located for me, but i did end up buying some better ones from here http://www.topretro.net/Pages/Top_retro ... roues.aspx
m100sandra
Postby m100sandra » Fri 29.11.2013, 22:34
m100sandra
Postby Peter D » Tue 03.12.2013, 21:10
No worries, nothing urgent on my side.
I got back into the details, and got confused again.
Seems like you have 90° cone ER03 ?
I'll go back to Speedline to have the cone angle rechecked and confirmed.
Conversion studs I found at demon-tweeks.
Speedline informed me there is a shaft of +/- 25mm, so 60mm conversion studs will be just O.K. or do ou suggest 80mm studs and cut them to length ?
Interesting is that this 25mm shaft, may result in the possibility to machine the wheels to the desired 60mm offset.
1. Needs to be checked with the wheel in hands (or with drawing, but I doubt I'll be able to get hold of a technical drawing)
2. Will a 7mm offset increase be possible, in combination with my 16" Hi-Spec brake kit ?
I noticed you've got Hi-Spec as well, what is the clearance between brake claw and the spokes of the Speedline ?
No rush, my Elan is in winter storage now.
Peter D
Postby m100sandra » Wed 04.12.2013, 08:32
BDC Peter wrote:No worries, nothing urgent on my side.
2. Will a 7mm offset increase be possible, in combination with my 163 Hi-Spec brake kit ?
Ime sure i ended up getting 80mm studs as the 60mm didnt allow enough turns on the wheel nuts, and as you mentioned they need cutting, 5-10mm?.
The caliper clearance to the spokes is massive :-) you could just about put two calipers side by side :-) GrA wheels :-)
The lug nuts in the link i posted are much better quality then i received from Speedline.
Cant remember the exact weight, but with tires they are much lighter then the standard wheels......
m100sandra
Postby m100sandra » Tue 01.04.2014, 13:56
Now BLACK :twisted:
m100sandra
Postby dapinky » Tue 01.04.2014, 15:07
I like them ! (in black)..... not that it's any great recomendation, but they do look good.
Postby Scott J » Thu 03.04.2014, 18:10
Black Beastie fitted with Gold Pro race 1.2s
Scott J
The prodigal son
Return to Wheels and Tyres
