Wheel centre caps
Wheel centre caps
Postby PAUL30 » Thu 19.03.2009, 23:08
I have the original style wheels on my car except they are 16 inch rims. The centre caps already on the car are 50mm. I have searched this site and the web and can't seem to find any in that size. Can any one advise.
PAUL30
Re: Wheel centre caps
Postby dapinky » Fri 20.03.2009, 11:16
Paul,
Let me see if i understand you here......
When you say you have original style wheels, in a 16" diameter, do you mean the S2 wheels made by BBS (basically a 5-spoke design), or the SE/NA wheels made by OZ.
If they look like the SE/NA wheels, but are definately 16", then it sounds like you have the Fed wheels (similar in looks to the 15", but the 'spokes' are straight (radially), not swept slightly backwards (or forwards on the other side of the car!).
I suspect we are talking about OZ Federal wheels, in which case the centre cap is the same as the SE/NA, and actually has an Esprit part number (which someone with a better memory will be able to quote).
They should still be availlable from Lotus Aftersales, and cost about a fiver each (that's for the whole thing, not just the badge).
Postby PAUL30 » Fri 20.03.2009, 12:06
Yep oz federal wheels, couldn't remember that last night :lol: .
I did come across the part number for the esprit ones. Cheers, will track that down again and check the aftersales list.
PAUL30
Postby dapinky » Fri 20.03.2009, 12:50
A082G6071F :wink:
Postby Jackonicko » Fri 20.03.2009, 15:30
I'll swap em for a set of 15 in OZ wheels, if you like!
Jackonicko
Postby GeoffSmith » Fri 20.03.2009, 15:39
Jackonicko wrote:I'll swap em for a set of 15 in OZ wheels, if you like!
Set of Oz wheels for a set of centre caps........ Billy Bargain! :twisted:
Postby PAUL30 » Fri 20.03.2009, 16:20
dapinky wrote:A082G6071F :wink:
Cheers!!!
PAUL30
Return to Wheels and Tyres
