Does anyone know where I can source two wheels urgently, or failing that, borrow two wheels to get the car through the MOT and back home?
Any suggestions greatly appreciated.
HJ2 wrote:Hi Mark,
Why not repair them?
There are lots of repair shops who heat them up and push them back into the correct shape on a lathe.
Faster and cheaper than new wheels
Good luck!
theelanman wrote:HJ2 wrote:Hi Mark,
Good luck!
not quite sure they could do that in time.....
also when did the trueness of the wheel come in?....
muley wrote:Mark,
Keep up at the back there. If you have 15" wheels, my spare set are 16" S2. Surely you'd want the same all round.
Rgds
muley wrote:Will it pass an MOT with different size wheels though?
theelanman wrote:sounds like it should.....
Tyres on the same axle must be of the same structure and size....
DavidEJM wrote:I've got a set of 15's, you can borrow a couple if you like and I'm just up the m40. Only issue would be that they are a bit rough and I don't know how good the tyres are. I can have a look if you can't find any closer you.
HJ2 wrote:Repair takes 20 minutes per wheel ...
