wheel centre badges for S2
Postby transcup » Tue 28.06.2016, 18:05
I am looking to replace the wheel centre badges on the S2 with BBS 16" wheels.
I think to replace the 4 centres are £19 each .
The existing black plastic is Ok, just the badges look a little tatty
It would make sense to replace the badge only
Can you recommend the correct badge size and a good supplier
There are plenty on ebay from china / hong kong , who has tried these and can recommend
transcup
Re: wheel centre badges for S2
Postby Saltire » Tue 28.06.2016, 18:17
When I wanted to replace mine, SJS couldn't supply proper ones. I had to go with the Elise centres, which are very slightly different in diameter.
This post talks about a chap who can make up the badges sized to suit. I tried contacting him on here and by email, but he only seems to respond to Facebook messages. And I'm not on Facebook :roll:
Postby Fredjohn » Tue 28.06.2016, 18:58
Try demon graphics, according to website they'll make any size you want.
http://www.demongraphics.co.uk
Just search Lotus under wheel badges.
Postby clemo » Thu 05.10.2017, 22:23
Wayne in Bahrain sells S2 centre caps ,
Though i cant find an ebay link for them .
I will post one when they are back on .
clemo
Postby Essex » Sat 18.04.2020, 13:12
Just wanted to say thanks for the link to Demongraphics. My centre caps were awful so I ordered a set (53mm) an am very happy. Look like new now.
Essex
Postby wayne » Tue 21.04.2020, 05:57
clemo wrote:Wayne in Bahrain sells S2 centre caps ,
Dave, I've currently cancelled all of my eBay sales as post offices here are closed on 26 March and I am not sure if they have reopened as I tend to stay at home and I'm concerned about delivery delays.
I do have a few sets of the original (reproduction) Lotus yellow and green caps available and a few of the black and silver caps. But I have no way of posting them out other than DHL.
http://www.elanm100.com
wayne
Postby Kathryn » Sat 07.08.2021, 18:52
Essex wrote:Just wanted to say thanks for the link to Demongraphics. My centre caps were awful so I ordered a set (53mm) an am very happy. Look like new now.
Same here. Thanks for the recommendation, they are superb. The colour is an excellent match.
Palacio S2 #540
Kathryn
Postby roy666 » Tue 10.12.2024, 15:33
Gents - It's finally happened..I've lost the plastic centre cap off the wheel (S2)! I thought I had seen someone who had 3D printed a bunch of them for sale. I went down the route of refurbing the cap badge/logo with some good decals a while ago and it has worked v well...but now I've lost the actual centre cap (which was sikaflexed in place!). Looking at the cost of a single S2 (53mm) cap from the usual bunch (PNM, SJs) is just so depressing (where do THEY source these things from anyway?). Any assistance on sources would be gratefully received. ta Mike
roy666
Postby Tuga2112 » Tue 10.12.2024, 16:05
check how much it will cost from shapeways.
i can 3d print one that is found on thingyverse,
if it works or not. i have no idea.
When I moddeled my own SE caps I needed 8 iterations to get the measurements right for my wheels/printer combination. no idea if the S2 files from thingyverse would come out as a straight fit.
Postby MikeM » Tue 10.12.2024, 22:31
If you're happy with cheap and cheerful then these will fit. The badge is slightly bigger at 56mm so overlaps the hole in the wheel, plus the yellow is slightly green.
https://www.ebay.co.uk/itm/276688669861?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=ulTKPUu8RAW&sssrc=2047675&ssuid=4wNRhx45TSy&widget_ver=artemis&media=COPY
Looks like this
They currently show as out off stock, but they seem to reappear every so often. Alternatively there are lots of 3rd party BBS caps that will fit the wheel, you just then need to source a badge.
Mike
If you can read this, the Caterham is in the garage and the Elan is on the road.
MikeM
Postby roy666 » Mon 16.12.2024, 19:10
Thanks Mike... I'm happy re the logo badge...its the plastic cap I'm after. You say "there are lots of 3rd party BSS caps"..; I've had a look around but can't seem to find any. Can you provide some detail..cheers M
roy666
Postby MikeM » Mon 16.12.2024, 22:37
There are lots of generic caps on Ebay or Amazon. If you search for BBS 56mm wheel caps you'll find them.
Here's another example https://www.ebay.co.uk/itm/363669457125
I bought a set of these because I wanted to make one wheel badge. I already had a Lotus bonnet badge of the right size and I glued it onto one of these generic caps.
I only bought the cheap Lotus ones because my MoT garage lost a wheel cap (and the hub dust cover) when they adjusted the rear wheel bearings - and then tole me they couldn't find them :evil:
Mike
MikeM
Postby JamieLM100 » Sat 25.01.2025, 07:09
Dumb question on a very old thread - so the centres are just stick on to the caps? mine look tatty and i want to try the 3D printed ones but sounds like if these are just glued on then the centres should be fine. Or did you just stick these over the old ones?
Thanks and apols for the throwback question!
JamieLM100
Postby JamieLM100 » Sat 25.01.2025, 07:28
roy666 wrote:Thanks Mike... I'm happy re the logo badge...its the plastic cap I'm after. You say "there are lots of 3rd party BSS caps"..; I've had a look around but can't seem to find any. Can you provide some detail..cheers M
Hi Mike - I found a 3D print file and a place to make them. I'll let you know how they turn out because if they are any good I will order a set, can do a +1 at cost and post to you if you still need one. Not due to arrive until mid-Feb.
JamieLM100
Postby MikeM » Sat 25.01.2025, 23:07
Thanks for the offer, but I have 6 spare generic centre caps from eBay. Three with BBS logos and three with cheap Lotus logos.
What would be useful is a source of good colour, 55 or 54mm Lotus badges at a reasonable price to glue onto the centre caps. The logo on the caps for the OZ wheels would work but would be an expensive way of doing it.
Mike
MikeM
Postby JamieLM100 » Sat 15.02.2025, 12:35
Hi Wayne - I tried contacting you via the site - do you have any S2 caps left? Many thanks
JamieLM100
Return to Wheels and Tyres
