et 25
et 25
Postby pietro » Tue 22.10.2024, 07:14
hi
here I am again
i'm getting et 25 rims. does anyone know if they touch the suspension calipers or fenders?
thanks guys
in the desert only the Bedouins and the Gods feel at ease.
And you, Lawrence, are none of these
pietro
Re: et 25
Postby Jamie N » Tue 22.10.2024, 08:49
I wouldn't recommend it Pietro, your wheels will sit too far out, you really want to go no lower than 45.
If you do though let us see the pictures. :wink:
Monaco S2 #406
Jamie N
Seal God
Re: et 25
Postby pietro » Tue 22.10.2024, 11:24
thanks for the reply
i will try et 30, i took some measurements and they should be fine.
as soon as i mount them i will post the photos and the sensations. bye have a good day
pietro
Re: et 25
Postby dapinky » Tue 22.10.2024, 11:33
There are 2 things which will affect your question, there is the ET (which is +60 on a standard Lotus wheel), then there is also the width of the wheel rim (which is either 6.5" or 7").
If you fit a wheel with +30 ET, and it is still 7" width, then there is a chance that you will hit the wheelarch on the bodywork.
I have seen cars with ET42 being very close, so I would suspect problems with anything less...... but until you fit them, it is hard to say for sure if you can just trim down the wheelarch to make it right.
I may look better, but the handling will suffer (you may or may not be able to notice it, depending on your driving style anyway).
Re: et 25
Postby pietro » Tue 22.10.2024, 11:44
thanks. i took et 30. but i paid very little. the idea is to try them and see how they go,
worst case scenario i'll resell them.
i measured the rear and there are no problems, there could be some at the front, but i won't know until i mount them.
but i saw here in the wheels section that many have mounted different rims without problems, and some even 17.
the driving style is sporty, but if i were to go to the track i would mount the original rims. let's see, i've had the car for a month i have to understand
pietro
Re: et 25
Postby Fredjohn » Tue 22.10.2024, 19:10
A website exists where if you enter your original wheel size ie diameter, rim width and offset (et number) and also your tyre size, then in another section enter all the same info for a new proposed wheel and tyre combination, it will tell you how much more (or less) clearance there will be. It will also tell you a revised speedo reading if you altered the overall diameter of wheel and tyre.
Unfortunately I can't recall the web address, but I'm sure I posted it on here a few years ago!
EDIT
Found it : https://www.wheel-size.com/calc/?wheel1 ... 0mm&sr=0mm
Hope this makes sense.
Re: et 25
Postby pietro » Thu 24.10.2024, 07:36
hi. yes i already did it, it comes out 3 cm compared to the original -60 wheel. i should be there.
i paid little for the rims, 150 euro, they are "star" very similar to the originals, as soon as i can i will post a photo.
i am very curious both from an aesthetic point of view, always very important, and from the driving. we will see how it goes.
pietro
Return to Wheels and Tyres
